Scenes repeat playing
tiefighterblue
Post by tiefighterblue »
hello,
I've been having problems with my finished DVDs. First problem is that when I play my DVD every thing appears fine. But when I fast forward through a scene to its end the DVD starts back at the begining of that scene playing it again. It works fine in normal play mode. I did notice that the scenes that repeat are scenes that i downloaded into DVDWS2.
Should'nt I just be able to fast forward through the DVD without any scenes repeating?
Also, I 've been having trouble with scene selections. I created a short cut to certain scenes on my DVD, which consist of a couple of pages. But after I play the scene that I select it automactically returns to the very first page of my scene selection pages. Should'nt I just be able to select a scene and be able to watch my DVD til the very end?
Thanks,
Hobbit 7
squanix
scenes repeating
Post by squanix »
i don't quite get the first problem that you stated ... maybe you can elaborate more?
for the second problem ... i think it may have something to do with the playlist for that particular button. you can check your project then select that button then check the playlist options panel and see how that button is played out ... hope this helps
