Track in Sound Mixer mode suddenly plays at full volume or is completely silent
mgmax666
motherboard: HP Notebook 15-ac2121nr
processor: AMD Ryzen 5 5600H
ram: 32 GB
Video Card: GeForce GTX 1650
sound_card: Realtek
Hard_Drive_Capacity: 1 Tb SSD
Corel programs: VideoStudio Ultimate, PSP
Re: Track in Sound Mixer mode suddenly plays at full volume or is completely silent
Post by mgmax666 »
Ken Berry wrote: Sat Apr 15, 2023 7:39 pm Did you look in the NVidia control panel to see which GPU was being used: the Intel integrated one or your NVidia one. Setting hardware acceleration to AMD would achieve nothing positive since you don't have an AMD GPU. Your AMD hardware is a CPU not GPU. So it is a choice between Intel and NVidia, and you'll only know which one is being used if you look at the NVidia control panel as I described...
The other things you could try are once you have moved to render the project: try turning off or on Smart Render and Hardware Acceleration there. This may make the render rather longer, but it would be interesting to see if it eradicated your problems with the audio chopping and changing.
Yes, Nvidia is selected. There is no Intel integrated, since this is an AMD CPU. And yes, I tried with hardware acceleration both on and off. No difference at all.
Telling it to create the proxy files each time I open the project and then clicking on the affected clips and choosing "Reset Volume" is the only thing that provides a temporary solution. The problem keeps manifesting itself in different ways. In one section, I had an overlay track muted and it also didn't play the sound on the video track and in another section the sound of the video track got distorted and severely amplified to the point that it hurt my ear.
Sorry. I had looked up your AMD Ryzen 5 5600H CPU and saw that it had integrated graphics. I wrongly assumed that was Intel, but now see it is in fact AMD integrated graphics. But my point was still the same, and it did you no good anyway...
I'm afraid I can't think of anything more which might help, especially since I can't replicate your problem.
mgmax666
ram: 32 GB
sound_card: Realtek
Post by mgmax666 »
Before I give up for good and switch to DaVinci Resolve, I am going to try converting all the source files to MPG instead of MTS and seeing if it makes a difference. It is possible that there is a glitch because the MTS files are an old format. I'm just grasping at straws because I have old VS projects I'd rather keep while switching to DaVinci will require recreating them.
mgmax666
ram: 32 GB
sound_card: Realtek
Post by mgmax666 »
mgmax666 wrote: Sun Apr 16, 2023 1:43 am Before I give up for good and switch to DaVinci Resolve, I am going to try converting all the source files to MPG instead of MTS and seeing if it makes a difference. It is possible that there is a glitch because the MTS files are an old format. I'm just grasping at straws because I have old VS projects I'd rather keep while switching to DaVinci will require recreating them.
Update. The issue still happens, with all the source files as MPegs, on two computers. Additionally, every so often there is an "Invalid Parameter" error message while scrubbing. Support has been absolutely useless.
