Impossible to open MP4 file in VS2022
sheng-si
motherboard: Hp motherb
processor: amd
ram: 32 Gb
Hard_Drive_Capacity: 1 tb
Monitor/Display Make & Model: ASUS VG24VQR
Corel programs: paintshop pro Videostudio 2022
Post by sheng-si »
Strange enough, you can save videos with mp4 extensie.
But when you get a mp4 file from someone else, then it is not possible to open it.
Saw somewhere possibility to change the extension in MOV. But then still I can not open or import it.
The file is 4,4 Gbit Can that be THE problem. Time 2 hour 18 min.
A smaller file 177 Mb about 46 minuten can I open in VS2022
The other solution I found through google is:
http://www.brorsoft.com/video-to-softwa ... tudio.html
I am going to try that.
Because it is movie from a funeral and want to make subtitles in ti for familymembers with light hearing problems.
Admin FB Paintshop Pro NLD for dutch users.
canuck
operating_system: Windows 8.1
Re: Impossible to open MP4 file in VS2022
Post by canuck »
VS 2022 can open most mp4 time has nothing to do with it. If it doesn't then the mp4 file has some "strange" properties that are not standard
Another possibility is the codec used by the problem video. It is possible, for instance, that the video was made with the H.265 HEVC codec which also produces .mp4 video like that made by the H.264 codec. HEVC video is very high quality and smaller or more highly compressed than H.264 video. But it requires you to have the Microsoft HEVC Extension on your computer for Video Studio to be able to edit it. You can get the Extension from the Microsoft Store for a very small cost. You could even, with Windows 10, still get it free -- so do a Google search for how to get the free version.
The see if you have a H.265 mp4, if you can get the video into VS library page, even if not on the timeline, right click it and go to Properties. If not, unfortunately File Explorer won't give you the information. So do a Google search for a small and free program called MediaInfo, which will give far more information that you would ever want, but also tell you if it is HEVC/H.265.
TonyP
motherboard: Gigabtye X570 Elite
processor: AMD Ryzen 9 5950X 16core 32threads
ram: 32GB 3200
Video Card: Sapphire RX 6700XT 12GB
sound_card: Realtek
Hard_Drive_Capacity: 10TB
Monitor/Display Make & Model: LG 27" IPS 4k, Acer 24" 1920x1080
Corel programs: VS2023, PSP2023, Aftershot 3
Post by TonyP »
You can download MediaInfo from HERE.
It's free. When in install it (it's a tiny program), open it and drag your video on top of it.
In View>Tree. Take a screenshot and add it to your post.
Or View>Text, copy/paste in post.
rochrunner
Hard_Drive_Capacity: Rochester Hills
Post by rochrunner »
Pardon me for jumping in, but I'm having the same problem in VS2020. In fact, it can't import a MP4 that was originally rendered by an earlier version of VS back in 2015! Here's the info from the MediaInfo app:
General
Complete name : D:\Gordon Productions\Videos\Drag Racing\Purple Haze Intro.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (mp41/mp42)
File size : 282 MiB
Duration : 2 min 56 s
Overall bit rate mode : Variable
Overall bit rate : 13.4 Mb/s
Frame rate : 30.000 FPS
Encoded date : 2015-12-27 17:55:33 UTC
Tagged date : 2015-12-27 17:55:33 UTC
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Format settings, GOP : M=3, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 13.2 Mb/s
Maximum bit rate : 15.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.211
Stream size : 276 MiB (98%)
Language : English
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Constant
Bit rate : 256 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 5.38 MiB (2%)
Language : English
Any help appreciated. I even considered upgrading to VS 2023 but am not confident that this would work there. I also do very little video editing any longer and would be hard pressed to justify the expense.[font=][font=]
rochrunner
Follow-on to my previous post: I just rendered a new MP4 video from VS 2020, then started a new project and tried importing that video to the timeline. The program crashed back to the desktop. Seems like something other than the codec, maybe?
TonyP
ram: 32GB 3200
sound_card: Realtek
Post by TonyP »
I don't have VS2020 installed. How about a screenshot of your Export settings? What are they?
Are you able to share the video Purple Haze Intro, you would have to upload to a share site, One Drive, Google Drive, Dropbox etc.
We can then try on our systems.
It does seem unusual that this video is giving problems
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
I have 2020 and don't have such issue.
Panasonic X900m, VXF1
sheng-si
processor: amd
ram: 32 Gb
Post by sheng-si »
TonyP wrote: Wed Apr 05, 2023 4:31 pm You can download MediaInfo from HERE.
THNX for the link to mediainfo, works easily.
THIS is the screenshot
and for complete also the text I see nothing about H.264 or 265 - google in wikipedia says AVC 1 = H.264
In between I used brorsoft convert it to mpg Can see it now and edit it in VS2022
Format settings, GOP : M=4, N=90
Codec ID : avc1
Duration : 2 h 18 min
Bit rate : 4 343 kb/s
Nominal bit rate : 5 000 kb/s
Frame rate mode : Variable
Minimum frame rate : 29.412 FPS
Maximum frame rate : 30.303 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.070
Stream size : 4.21 GiB (94%)
Writing library : x264 core 163 r3059 b684ebe
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=16 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / stitchable=1 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=infinite / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=20 / rc=abr / mbtree=1 / bitrate=5000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=6000 / vbv_bufsize=5500 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Audio
Format : AAC LC
Bit rate : 265 kb/s
Stream size : 260 MiB (6%)
Default : Yes
Alternate group : 1
Two things regarding the video
1. Codec is AV1 video, I do not think 2022 supports av1, 2023 however has been updated and should support av1, I would suggest downloading the trial to see if that works.
2. The frame rate is variable, video studio has had problems running variable frame rates
As you converted the video I assume that would use a constant frame rate, although I would have converted to mp4 avc (not avc1) rather than mpg
Again try the trial version 2023, or provide us with a short sample and we can test for you
Hi sheng-si
I managed to download the avc1 video from vimeo, that did not open using 2022 or 2023 both giving a file format mismatch
Whilst viewing Media Info I noticed at the top a promotion for WinX Hd Converter
That seemed to convert the video retaining AVC1, the first attempt was a 5 minute trial convert. I had struggled using other converters, the Win X seemed easier to use just choosing the recommended profile.
The converted videos opened using 2022 and 2023
Note that the video I downloaded from Vimeo was using 25fps whereas your video used 30fps
Videos when added to the timelines did show the messages to match the project settings, video played on my system without smart proxy, a little surprised at that.
The overall data rate had ben reduced from 3 Mb to 2 Mb which reflected on the Gb size of the file.
Trevor -- can you give me the link the Vimeo which you used. I have been searching for an AVC1 sample, but without much luck so far. Everything far is telling me AVC1 is synonymous with H.264, and a couple of samples which identified themselves as AVC1 in their downloads appeared in VS as h.264 .mp4 and played and inserted perfectly in VS.
Trevor sent me the Vimeo link and I downloaded the clip. However, like Trevor, I could not open it in VS 2023 and got the same File Format Mismatch error as Trevor. MediaInfo said the codec used was "mp42" -- I have never seen that added 2 before.
I decided to try to convert it using Handbrake. That turned into a disaster. I set it to 25 fps 1920 x 1080, standard mp4. The conversion began but said it would take just under 20 minutes. It went for a few minutes, but then the computer crashed! I don't mean the program -- the whole computer did. However, it was the strangest crash I have ever seen. The computer itself showed its main operating lights as being on, though a little yellow light that it has to show it is doing things was not turned on. The monitor reported no signal. And when I tried to turn off the computer by pressing the start button for the usual 10 seconds or more, nothing happened! I had to physically pull out the power cord to turn off the lights. When I reinserted the cord and pressed the start button, everything started up again and it all works properly. I am a bit dubious, though, about continuing the experiments...
Anyway, I downloaded the conversion Trevor had made using WinX converter, and like him, found that it worked perfectly in VS. I might note that the original video was 3.36 GB in size, while the conversion was only 1.91 GB -- though the difference in size was possibly because, as Trevor indicated, only a 'trial' conversion.
sheng-si
I have sent you a private message containing a link for the converted video
