Magic Wand Tool Help
twins225
processor: 11th Gen Intel Core i7
ram: 32GB
Hard_Drive_Capacity: 1TB
Corel programs: PSP 2022 64-bit
Post by twins225 »
I am trying to make decorative wood grain papers (for a digital scrapbooking kit).
I achieved this last week, but I didn't save my settings and now I can't get it right.
I am trying to select the wood grain texture from the paper, to manipulate with another paper.
Previously, when I used the tool, it worked, but nothing I am trying now will work.
This is the finished product I am trying to achieve. Hope my explanation makes sense.
Anyone have any suggestions?
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Magic Wand Tool Help
Post by LeviFiction »
I'm confused, is this a wallpaper pattern on a top layer with a wood paneling picture on the bottom layer and you used the magic wand tool to select the pattern, and hit delete? Or is the wood grain on top and the wallpaper pattern is what's showing through? What is the process you used? Did you invert the selection before deleting or is what's left everything that wasn't selected? I can see the final result, but I have no idea at what stage you used the magic wand tool. If you can it would also be helpful to see the starting point images you're working with.
I don't suppose you saved it in PSPImage format before exporting to JPG did you? I don't see an edit history in the jpg file so either you have that turned off or it was removed.
With the magic wand tool it's just as much where you click as it is what your settings were. Normally PSP saves your last used settings so that the tool is set up the last way you used it. Since you've been playing around trying to do it again you've clearly overwritten those settings.
If I had to guess, I would assume you used anti-alias, no feather. As you get most of the wood grain remaining I'm assuming Color or RGB or lightness with a high-enough tolerance to grab a lot of the texture. And unless you made a lot of clicks with the selection mode set to "Add" I assume you had "Contiguous" turned off to make it a single click mass selection. Best I can do.
twins225
ram: 32GB
Post by twins225 »
I tried all the settings, to no avail. It's just picking up dots everywhere, none of the grain like it did before.
I'm kicking myself now, for not saving the settings.
Its the regular paper on top, wood paper below.
Magic wand was the first step, used on the wood paper.
Inverted the selection and deleted it from the top layer (regular paper).
I did save a few layered files, so I will search through them tomorrow.
Top Paper:
Bottom Paper:
Final Product:
ram: 6 GB
As I said where you click is just as important as the settings. Because you inverted the selection I'm looking to click somewhere near or on the woodgrain, or at least one of the darker browns.
Using the built-in settings of: Match Mode - Color, Tolerance - 12, Contiguous - Off, anti-alias - On.
I clicked on pixel (1805x,1945y) and got this result. Which isn't exact, but it looks like it's getting close. But without knowing where you clicked exactly, all of this will be guess-work and aiming at getting close to what you had before.
twins225
ram: 32GB
Post by twins225 »
Thank you. I will try the settings you suggested later today.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
Use the Layers Properties Blend Range:
twins225
ram: 32GB
Post by twins225 »
Jean-Luc wrote: Fri Mar 31, 2023 12:58 pm Use the Layers Properties Blend Range:
Awesome!!!! This worked. I never thought of this! THANK YOU!
twins225
ram: 32GB
Post by twins225 »
LeviFiction wrote: Fri Mar 31, 2023 2:50 am
Thank you Levi, your settings worked too!!! YAY!
