Is there anything like "snap to" for cutting clips
hanness
Maybe I'm doing this wrong since I'm a bit used to Adobe Premiere, but in both Media Studio Pro 7 and 8 Preview I'm having a little difficulty cutting clips in the timeline.
In Premiere when you select the razor tool and then move it near the current time indicator it snaps to the position of the time indicator so that you get a cut at precisely the point where the time indicator is.
In MSP I find that this does not happen. As a result I have to zoom in on the timeline to the point where individual frames are visible so that I can cut with frame accuracy. I then need to zoom back out again, then in again when I want to perform another cut. This gets tedious in a hurry.
I'm sure I'm missing a better way - can anyone tell me what I may be missing?
Hannes
Hannes
MonroePoteet
I don't know of a way to "snap to scrub position", but I'd like to see it. Better yet, a "cut at scrub position" in the menu, similar to what's in the Source Window.
I do what you're talking about in two ways:
1) I use the "Previous Zoom" quite a bit. This is tied to F9 by default. So, I scrub at a fairly large view, then zoom in to 1-frame or some other closeup view to do precision cutting. After doing this once, use F9 to switch back and forth.
2) I use the "Source Window" a lot for cutting up clips. It has a "Cut at Current Position" (a feature I wish the Preview Window had). I'd do this all the time if: a) the scrub slider in the Source Window was ONLY for the currently selected clip, or b) the jog-shuttle speed was more than 2X.
Using the Source Window, I can double-click a clip into it, play and shuttle, and fine-tune the position using the left/right arrow keys, then use "Cut at Current Position" to make the cut.
I'm hoping the scrub slider in the Source Window for MSP8 is fixed. In MSP7, it's *very* bizarre, with the thumb portion of the slider able to leave the slider altogether. The slider represents the whole timeline, but *should* only represent the current clip range in it, IMO.
mTp
mTp
Terry Stetler
MonroePoteet
Terry Stetler
MonroePoteet
Terry Stetler
Re: Is there anything like "snap to" for cutting c
I've used MSP 6 and all SP versions of 7, and they all "snap to" the preview marker, preview range edges, clip edges and cue points. Haven't tried v8 yet - so I don't know what the menu options are, or if this feature is even continued, but it's pretty fundamental and so unlikely to have been removed.hanness wrote:In Premiere when you select the razor tool and then move it near the current time indicator it snaps to the position of the time indicator so that you get a cut at precisely the point where the time indicator is.
It sounds like you've turned the feature off. "Edit" "Snap"
MonroePoteet
The Scissors tool doesn't do this "snap to position" for me in MSP V7, and I have Edit=>Snap checked.
Here's my scenario:
I have a single clip with one title fading out and another fading in. There is one, single frame where neither title is showing, and I want to cut there.
If I use the left/right arrows in the Preview Window to place the scrub exactly where I want the cut, then position the Scissors tool as precisely as I can on the Scrub position (using shortcut "s") and cut, I get the last frame of the fading-out title in my new clip.
If I set the scrub position as before, but then zoom in to 1-Frame before using the scissors tool to cut, I get what I want: the first frame of the new clip has no title on it, and the new title fades in immediately.
mTp
Here's my scenario:
mTp
MonroePoteet
After some experimenting I got this to work. Thanks for the clues. Unfortunately, the first project I tried this on, the "s" scissors tool moves the scrub point, so it was even *more* "larking about" to get it to work. I think it had to do with my project settings or the source material, since it works fine on other projects.
So, the one-liner solution to the original post (knowing what I know now) would be:
"In Stitch Trim mode, you can drag the cut point, and it will snap to the scrub position."
I'd still like to see the scissors tool snap to the scrub position, or have a Preview Window menu item for "Cut at Current Position".
Thanks again for the clues.
mTp
mTp
hanness
Working much better now!
Thanks for the responses - I knew there there had to be better ways and sure enough there are.
Hannes
Hannes
