Script Error
Monteiro
operating_system: Windows 8.1
Script Error
Post by Monteiro »
Hello.
I'm trying to run the GridByPercent script but I keep getting this error.
Image[url=https://flic. kr/p/2ooo1A1]Image1[/url] by José Monteiro, on Flickr
Image[url=https://flic. kr/p/2ookuZ4]Image2[/url] by José Monteiro, on Flickr
Can you help me?
Kathy_9
Hard_Drive_Capacity: 2TB
Re: Script Error
Post by Kathy_9 »
The answer is in the error message. If you trust the source/script writer of the script, you need to move the script to the Trusted Scripts folder. It's currently in the Restricted Scripts folder. If this is one of LeviFiction's scripts you can certainly trust him.
Monteiro
Re: Script Error
Post by Monteiro »
Kathy_9 wrote: Tue Mar 21, 2023 2:01 pm The answer is in the error message. If you trust the source/script writer of the script, you need to move the script to the Trusted Scripts folder. It's currently in the Restricted Scripts folder. If this is one of LeviFiction's scripts you can certainly trust him.
Thanks for your response. However I already changed the scripts to the folder you said but the problem persists :(
Kathy_9
Re: Script Error
Post by Kathy_9 »
One other thought. Did you just copy it to Trusted and leave a copy in Restricted? If so, remove it from Restricted, close and restart the program and see if that helps. If that doesn't work, hopefully Levi will come along with an answer as he is far more knowledgeable in this area than I am.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Script Error
Post by LeviFiction »
If a script of the same name exists in both folders the one in the restricted folder will be run every time. So if you copied the script over but still left a copy in the restricted folder it'll act the same way.
Also if you run a script by going File -> Script -> Run that will always run a script in restricted mode regardless of where the script is.
Last thing to check is the file locations. Make sure that Scripts-Trusted folder is not listed under Scripts-Restricted. File -> Preferences -> File Locations.
Monteiro
Re: Script Error
Post by Monteiro »
LeviFiction wrote: Tue Mar 21, 2023 2:28 pm If a script of the same name exists in both folders the one in the restricted folder will be run every time. So if you copied the script over but still left a copy in the restricted folder it'll act the same way.
Tks. Woks now. :wink:
