I have put together a montage of photos and wanted to add a background track to them.
I added the photos onto the Video timeline with a simple transition between each photo. I also added a .wav file as a sound track but I cant get both to play at the same time.
If I click on the Video timeline and click play the photos play but the soundtrack doesn't. If I click on the Music1 timeline, the music plays but not the photos?
What am I doing wrong
Thanks in advance
No sound from .wav file
detectingdavid
- System_Drive: D
- Hard_Drive_Capacity: Upminster
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Re: No sound from .wav file
You do not need to highlight any track, just select "Project" then play. If you highlight a track, then "Clip" mode is activated, then only the highlighted track will play
detectingdavid
- System_Drive: D
Great Robert, that's sorted.
Thanks a lot for your help
