Smart Proxy - ProRes Vs Custom
RickMen
motherboard: Gigabyte B660M GAMING AC DDR4
processor: Intel i7-12700F
Video Card: NVIDIA GeForce GT 730
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500GB M2 PCIe NVMe SDD
Monitor/Display Make & Model: Philips 246V5 24inch wide LCD
Corel programs: VS2022 Ultimate, VS2018 Ultimate
Post by RickMen »
I just upgraded from VS2018 to VS2022. In VS2018 my Smart Proxy settings for Video proxy were set to custom option:-
MPEG files
24 bits, 720x576, 25fps
Upper Field First
DVD-PAL 16:9
Video data Rate variable 6000kps
I read the user guide and it didn’t answer my question(s). What is the advantage of using the ProRes option? Why is it recommended? I prefer a smaller proxy file to save disk space & CPU processing. Can someone give a quick overview of the pros & cons? Thanks.
VS2022 ProRes settings:
MPEG Transport-Stream Files
24 bits, 1920 x 1080, 25 fps
Upper Field First
(HDMV-PAL), 16:9
H.264 Video
Video data rate: Variable (Max. 18000 kbps)
Audio data rate: 384 kbps
Sony FDR-AX53, JVC Everio GZ-HD40
Vdanny
Video Card: Nvidia 1060 6GB
Re: Smart Proxy - ProRes Vs Custom
Post by Vdanny »
ProRes video files are not as compressed as mpeg so usually require less CPU power to decode so the timeline runs smoother. The trade-off is that the file size is larger. For my system, I notice an improvement in performance when using the ProRes option.
Hi Vdanny2
Thanks for your reply here.
I noticed there was another account in the name “Vdanny” and was wondering if this new account is a duplication.
The last post being here, https://forum.corel.com/viewtopic.php?p=392237#p392237
Can you confirm if this is you or not.
If it is a duplicate account can you please contact Admin at contactcorelwebboard@corel.com to discuss your preferred E-mail address
RickMen
Post by RickMen »
Vdanny2 wrote: Wed Feb 01, 2023 8:34 pm Hi,
So if I reduce the bit rate to say 6,000 kbps (via create Custom version of the standard ProRes file) will I retain the performance aspect as well as reduce the size of the proxy files?
Vdanny
Post by Vdanny »
ProRes uses intra-frame compression so that each frame is stored individually. You should be able to significantly lower the bitrate while retaining the performance boost before serious visual degradation of the proxy sets in.
lata wrote: Thu Feb 02, 2023 11:30 am Hi Vdanny2
Vdanny
Post by Vdanny »
Hi lata,
It is me, I contacted admin yesterday.
RickMen
Post by RickMen »
Well I've reduced the bit rate to 6,000 kbps and I see how I go.
Vdanny wrote: Fri Feb 03, 2023 9:21 pm Hi lata,
Thanks Dan, your account has been updated,
I have provided you with a temporary password and have sent you an e-mail with your details
Regards
Vdanny
Post by Vdanny »
Hi RickMen,
I just edited a video with Videostudio and didn't see a way to alter the default ProRes bitrate. The custom setting only seemed to offer MPEG-4 settings or other formats when creating a new template, but not ProRes.
PS Thanks, Trevor!
RickMen
Post by RickMen »
Oh....so much for that idea. Thanks Vdanny.
RickMen
Post by RickMen »
So the setting in the dialog box relate to Custom template even when the ProRes option is selected?
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
RickMen wrote: So the setting in the dialog box relate to Custom template even when the ProRes option is selected?
Yes as mentioned in the user guide, proxy files are either ProRes or Custom.
tletter
Vdanny
Post by Vdanny »
Hi Rickmen,
That appears to be the case. The "custom" selection shows an mpeg transport stream which is definitely not ProRes. I went through the list of available formats and ProRes wasn't among them. Perhaps this will be an option in a future release. If you have the storage available this really isn't an issue since you can delete the proxy files after completing the project. I edit 4K mp4 files and it is a much smoother experience using the ProRes proxies.
RickMen
Post by RickMen »
Vdanny wrote: Sun Feb 05, 2023 12:59 am Hi Rickmen,
Thanks Vdanny. I will experiment in due course.
