Issue with cutting audio files
BROTHERKB
System_Drive: B
Post by BROTHERKB »
Greetings,
Working in VSP 2022 Pro and encountering an issue. When I cut an audio file and play the clip it contains the desired audio, but when I play the same clip in the full program it is clipped at different points. When I render I get the audio I don't want. I tried rendering just one clip (as opposed to the fill project) and have the same issue. I turned the scrubber off and still have the same issue. I did not encounter this problem using the trial; only in the purchased version. Any ideas? Thanks' in advance!
BK
Re: Issue with cutting audio files
Can you provide a little more information regarding the Audio file
I assume the problem is specific to your audio files and that using the library samples are ok.
Some MP3 audio uses a Lame Codec ( do a google search for details)
Video Studio has had issues using this codec at least for some users.
If your audio are indeed MP3 Lame Codec you will be best to convert to Wav before editing. Audacity has been used by forum members.
Are you able to share the audio files with us. If you create a VSP containing the problem audio you can save the VSP to share that with us along with the audio file.
