Out of Memory in PSP 2022
Leslie
processor: intel core i7
ram: 32 gb
Video Card: intel iris
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell Inspiron 7700 27 All-in-One Desktop
Corel programs: 2019 Ultimate, 2022 Ultimate
Post by Leslie »
I got this message in 2022. I closed everything but psp, and still got the message.
I hope I attached it correctly.
tia
Leslie
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Out of Memory in PSP 2022
Post by LeviFiction »
32-bit or 64-bit?
Leslie
ram: 32 gb
Post by Leslie »
I believe it''s 32 because all my old plugins work. But not positive.
ram: 6 GB
32-bit can only access so much memory, though most of the time it's more than enough to do most things, it all depends on what you've been doing. While I can't guarantee any of these suggestions will help here are the things I would check first.
1) Turn on Scratch-disk if it's not already turned on. I believe it's on by default these days but just double check. File -> Preferences -> General Program Preferences. Display and Caching. Turn on Scratch disk.
2) If you haven't already, turn off saving edit history. Also in general preferences under "Miscellaneous". People who do a lot of brush work or textures and patterns can quickly build up a giant history of information that gets stored in RAM and later in the file after you save making the file huge. It can also reveal sensitive information accidentally. Unless you need it, it's recommended to turn it off.
3) Save your image as is right now, and restart PSP. Hopefully the changes will make it workable. If the saved PSPImage file is huge you can try running my History Remove script - https://forum.corel.com/viewtopic.php?t=64207
It creates a copy of your file without the saved history. Which, depending on the size of your history information could be a lot or very little.
Leslie
ram: 32 gb
Post by Leslie »
I did everything except run the script, as when I went to the link I couldn't find a place to download it.
Still get the same message. :(
ram: 6 GB
For the script, when you go to the GitHub page, click on the green "Code" button. There will be a "Download Zip" link in the drop-down menu that shows up.
Leslie
ram: 32 gb
Post by Leslie »
Thanks. I ran it but it didn't help.
ram: 6 GB
So how big is your image and what is the function you're trying to perform?
Leslie
ram: 32 gb
Post by Leslie »
454 x 340
Trying plugin Simple/diamonds
patara
motherboard: ASUS Prime Z690 DDR5
processor: Intel i7-12700K CPU 12 Core
ram: 32 GB
Video Card: GeForce GTX 1060 GI Gaming 6G
sound_card: VIA High Definition Audio
Hard_Drive_Capacity: 1TB SSD +22TB Hard Drives
Monitor/Display Make & Model: Dell U2715H
Corel programs: PSP7 to PSP 2023
Post by patara »
Leslie wrote: Thu Jan 12, 2023 11:15 pm 454 x 340
Simple diamonds is a Filter Factory filter. Do you have the required dll in the system folder? It works fine in my PSP 2021 32 bit but I do use it inside the Filters Unlimited Plugin.
Leslie
ram: 32 gb
Post by Leslie »
I have it in the regular list of effects. All works fine in my psp 2019, so I guess all the dll's are there.
I even re-booted my computer.
patara
ram: 32 GB
Post by patara »
Leslie wrote: Fri Jan 13, 2023 4:26 pm I have it in the regular list of effects. All works fine in my psp 2019, so I guess all the dll's are there.
I got the same error message today in PSP 2023 64 bit and I have seen it in the past. I have 32GB ram so know system memory is not the problem.
If I recall in past errors it was always related to a selection or inverse selection on the image which I was not aware of.
That was what happened today. I had an image in PSP and I meant to do my normal screen capture using my browser but instead I made a PSP selection and then clicked copy.
The error appeared.
I then realised what I was doing. I had made a selection on a levels adjustment layer and was trying to copy it.
As a test I left the selection and used Copy Merged and there was no problem.
I then removed the selection and just used Copy on the Levels Layer and there was no problem.
As a final test with all selected I tried Copy on each layer in the image and there was no problems until I tried to copy the Levels Adjustment Layer and the error reappeared
So perhaps you have a selection or inverse selection on your image or it is the layer that is causing the problem.
Leslie
ram: 32 gb
Post by Leslie »
I tried it your way and it copied fine. I do have a selection on a promoted layer and one underneath.
But, I want to do the effect on the image with the selection.
Have you tried that?
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
Are you wanting to do the effect on the part of the image that is selected (so that the rest of the image isn't affected) or the part of the image outside of the selection so that the selected area isn't affected?
One workaround (assuming it is the selection marquee causing the issue) would be to first promote the selection to a layer then save the selection marquee to an alpha channel then delete it. Now you don't have a selection and you can apply the filter to your choice of the new layer or the previous layer as desired. Then merge the upper layer back down into the layer it came from. That way you would have the filter effect showing on whichever part of the image you wanted it on. And if you need the selection marquee for some other reason you can then recall it from the alpha channel.
As I don't have that filter I can't experiment to see it that works, or perhaps I misunderstood the issue and my suggestion wouldn't be feasible for your needs. Just a thought though.
JoeB
Using PSP 2019 64bit
patara
ram: 32 GB
Post by patara »
Leslie wrote: Sat Jan 14, 2023 1:45 pm I tried it your way and it copied fine. I do have a selection on a promoted layer and one underneath.
I wasn't trying to copy your steps Leslie, or use the filter. I was just commenting the error popped up for me today and from what I could see it was related to the selection and perhaps the layer I was on that I tried to copy.
I feel sure always in the past when I have got this error it has been due to a selection and when I selected None, whatever process I was trying to do would work.
I will open my PSP 2021 32 bit and see if there is an issue for me with that filter.
