Install service pack 3 and VS2022 closes without notice.
Choi seong chul
motherboard: Asus Z390
processor: InteCore i9 9900KF
ram: 64GB DDR4
Video Card: NVIDIA GeForce RTX 2080 Ti 11GB
sound_card: MAYA U5 External Sound Card
Monitor/Display Make & Model: LED Raantec 24"
Corel programs: CVS X4,- X10,2018-2022,2023
Post by Choi seong chul »
so install it again. If you click Preferences in Settings, the following
A message appears and Preferences is unavailable.
The only workaround is to turn the computer off and on a few times to fix it.
It got so weird. who has experienced it.
Cannot write to the specified disk.
Disk space may not be enough, disk may be write-protected.
or the file or path name is too long.
Re: Install service pack 3 and VS2022 closes without notice.
I do not know why the program crashes but could be associated with the ”write-protected” error
There is an issue that gives this warning when the Share – Save location is no longer available.
This will occur when saving to a folder or drive / usb that has been disconnected.
Please go to Share and choose another save location, does that help with the error message
When you re-installed did you also remove personal details, as doing that should have reset the Share – Save location, if of course this is the issue
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Post by Radim »
Choi seong chul wrote: Mon Jan 09, 2023 12:24 pm Install service pack 3 and VS2022 closes without notice.
Hi, you can try use a Process Monitor from Sysinternals ( https://learn.microsoft.com/sk-sk/sysin ... ds/procmon )
It is portable program.
1. Download and extract it (on Desktop), run EXE.
2. Set active only events that write to hardisk (SSD, HDD). Look image bellow.
3. Keep it running. Do clear all shown events (via icon on program menu).
4. Start Corel SP3 installer. When is shows error go to program and stop events recording.
5. Look into list to find hardisk errors.
Choi seong chul
ram: 64GB DDR4
So I tried installing VS 2021.
No problem at all with VS2021.
Did you check that the save location was available
Please view this post
https://forum.corel.com/viewtopic.php?p=319553#p319553
Choi seong chul
ram: 64GB DDR4
The storage location is not a problem.
It appears only in Preferences click in settings, nothing else
It seems fine.
Thank you for the conformation regarding the save location.
I can only suggest you re-install the program, first using the “cleanup tool” to remove the existing program.
