VS8 - how to display clip shot date & time
Xyzzy2
motherboard: MSI Z77MA-G45
processor: Intel i5-3570K
ram: 8 GB
Video Card: MSI R7770-2PMD1GD5 OC
sound_card: Realtek 892
Hard_Drive_Capacity: 6.25 TB
Monitor/Display Make & Model: HP ZR24w
Post by Xyzzy2 »
Hello!
I have split DV into clips. How can I display date&time when a clip was actually shot?
VS8
TIA
X.
THoff
Post by THoff »
You can see the date and time of original captured DV AVI files by accessing the file's Property dialog. If you render to a new file, that information will not be preserved.
UVS 9 adds the ability to overlay the timecode on top of the video in the Preview window.
missnz
Date and time
Post by missnz »
The only suggestion that I have would be putting in the date and time manually using the title part of video studio.
Michelle
erock1
Post by erock1 »
THoff wrote: UVS 9 adds the ability to overlay the timecode on top of the video in the Preview window.
THoff
I finally made the leap and upgraded to VS9 from 8. I haven't seen any mention in the manual of how to have the date/time code displayed as an overlay as you mentioned. I'm interested in this, can you explain.
TIA,
Erock
THoff
Post by THoff »
File -> Preferences -> General -> Display DV Date and Time in Preview Window (or whatever it's called, that's from memory)
Xyzzy2
ram: 8 GB
Post by Xyzzy2 »
THoff wrote:You can see the date and time of original captured DV AVI files by accessing the file's Property dialog. If you render to a new file, that information will not be preserved.
In Properties dialog (RMB on clip thumbnail in video library) there is no info about clip creation date. Only on tooltip there is some date displayed, but it is the same for all clips of a DV.
I do not want this info to be overlayed, I just want to know when a clip was shot. I think this info is recorded with DV stream.
X.
Xyzzy2
ram: 8 GB
Post by Xyzzy2 »
THoff wrote:File -> Preferences -> General -> Display DV Date and Time in Preview Window (or whatever it's called, that's from memory)
Could you check this? There is no such (or similar) option there :(
X.
squanix
display dv time
Post by squanix »
hi,
this "display DV time ..." option is only available in UVS 9 and not in 8. in uvs 9, it is in the path that Thoff mentions
erock,
i don't think you can actually use the date and time as text in your overlay track but only to display it in the preview window. however, i don't know if this is what you wanted to know ... hope this helps...
