Been using PSP 2023 ultimate for a few weeks and it's been great so far. But just starting yesterday
to remove some objects but it cannot it to work on this image.
Clone tool:
Right click to select the source then moving over to one side and holding down the left - does nothing. I have done this countless times in the last few weeks
and not had an issue.
smart clone tool also stopped working but after a "reset preferences / all" it now works.
My toolbar looks like this
Any advice would be great.
I also attached the "problem" image in case there's some issue with it.
Clone and smart clone - stopped working
thedavegray
thedavegray
Re: Clone and smart clone - stopped working
Here's a few second video on OneDrive which shows the problem: https://1drv.ms/v/s!Ah9cer_nAx90lLsnW0X ... w?e=tQdppL
thedavegray
Kathy_9
- Hard_Drive_Capacity: 2TB
You could first try resetting the clone tool as shown below
And if that doesn't work, reset PSP2023 to default. Instructions here - https://forum.corel.com/viewtopic.php?t=67616
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Things to check for selections you can't see. Selections -> Select None.
Make sure there are no new layers added, couldn't see the layers in your recording.
As Kathy_9 suggests, resetting the tool.
And if none of that works you may also want to try resetting the workspace to factory defaults.
