Delete key doesn't work
marq101
motherboard: MSI H110 ECO
processor: Intel Core i7-6700
Corel programs: PSP 2019-2023 ultimate
Post by marq101 »
Here we go again.
The delete key of my psp 2022 doesn't work. Reset to std values doesn't work, restart doesn't work. Can't work this way.
Help much appreciated
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Delete key doesn't work
Post by LeviFiction »
What do you mean "reset to std values" doesn't work? What method did you use?
Did you try this: View -> Customize -> Keyboard and hit the "Reset All" button. This resets all keyboard shortcuts.
You can also check to make sure it's actually assigned to a command like "Clear". Or make sure you're in a position where the "Clear" command can be run.
yakettyyak
operating_system: Windows 8.1
processor: AMD A10-6700 Radeon HD Graphics
ram: 8 GB
Post by yakettyyak »
I'm having the same problem. I wonder if you downloaded any freebies from Corel. Because my problem started after I recently downloaded freebies from Corel. I used to delete my selection using the Delete key. But it won't work anymore. The alternative I'm using now is the eraser tool or from the menu tab Edit--> Clear.
