annoying splash screen update
- miltk
- Video Card: nvidia gforce 1030
- Hard_Drive_Capacity: 250-500
- Monitor/Display Make & Model: LG 32MA68HY-P 32-Inch IPS Monitor
- Corel programs: psp x6 16.0.0.113
everytime i use pro xs psp, the program leaves a splash screen upgrade that i cannot get out of.
i end up having to bring up task manager to end the program. closing the splash screen doesn't help and i could not find a setting to stop the splash screen
can anyone help?
thx
w7
corel psp 116.0.0.113
can anyone help?
thx
w7
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: annoying splash screen update
What do you mean a splash screen update? Do you mean an advertisement for updating PSP?
- miltk
just some update promo stuffLeviFiction wrote: ↑Fri Nov 25, 2022 8:30 pm What do you mean a splash screen update? Do you mean an advertisement for updating PSP?
- miltk
when i try to exit i get this promo
there's images that my computer is not able to render. i cannot "x" out
Have you adjusted your Message Preferences in the Help menu?
- ram: 6 GB
Not Messages, message preferences. It's the next item down on the help menu list.
In this dialog, you turn off the receipt of updates. Just make sure everything is deselected and that the drop-down box says "Do not show me tray messages for this application".
- miltk
LeviFiction wrote: ↑Mon Nov 28, 2022 8:58 pm Not Messages, message preferences. It's the next item down on the help menu list.
no message preferences
- ram: 6 GB
Do you mean the menu item is missing? Or that they are all turned off? There are no default workspaces that don't have the Message Preferences option. I tested. So if you mean that your menu doesn't have the Message Preferences then you need to reset.
You can do this in one of two ways:
1) View -> Customize
2) In the Customize dialog select "Menu" from the tabs at the top
3) Hit the "Reset" button under the "Show Menus For" drop-down box. That should reset all menus to factory defaults.
Or you can reset the whole workspace (probably your best option). Instructions for this can be found here - https://forum.corel.com/viewtopic.php?t=67616
- miltk
i think i'll have to reinstall. almost everything in customize is greyed out except palettes, magnifier, and full screen modeLeviFiction wrote: ↑Tue Nov 29, 2022 8:03 pm Do you mean the menu item is missing? Or that they are all turned off? There are no default workspaces that don't have the Message Preferences option. I tested. So if you mean that your menu doesn't have the Message Preferences then you need to reset.
- ram: 6 GB
Are you using the Essentials Workspace or the Complete workspace? Essentials has less options than the Complete workspace.
- miltk
i don't know where to toggle betwenn the twoLeviFiction wrote: ↑Wed Nov 30, 2022 4:56 am Are you using the Essentials Workspace or the Complete workspace? Essentials has less options than the Complete workspace.
thx
Place your mouse cursor virtually anywhere in the working area or even the area up top occupied by the command menus. Right click and you should get a drop down menu with Workspace at the bottom. Select that and you should be presented with another menu showing inter alia Complete and Essentials (as well as Photography and Sea-to-Sky).
Kathy_9
- Hard_Drive_Capacity: 2TB
Or just go to File -> Workspace and select Complete.
- miltk
options in "workspace", whether i right click or file/workspace are
load
save
delete
recent is greyed out
load
save
delete
