So, re-download SP1:
https://www.paintshoppro.com/en/support ... /#psp-2023
//But info on update page is stil outdated...
EDIT: version is 25.1.0.32
So, we have two fully patched ("identical") version of PSP 2023 with different version number?LeviFiction wrote: ↑Mon Dec 12, 2022 5:03 pm 1 - Alludo is Corel or the overarching umbrella of Corel and their various owned properties.
2 - Here is the quick breakdown of actions based on the version #.
25.0.x.x - unpatched - install the Patch #1 to get 25.1.0.32
25.1.0.28 - Initial patch no hotfix - install hotfix for fastest update
25.1.0.32 - Patched Patch #1 no need to install anything
25.1.0.122 - You had the initial patch and you installed the hotfix. No further action needed.
3 - The Installer always grabs the most recent patched version when it runs. So if you installed 2023 after the patch had been updated you will be on the latest version of PSP 25.1.0.32. If you installed before the patch update it'll be an older version.
One recommended option if you didn't want to do the hotfix is to first uninstall your current version of 2023. Then re-run the installer it'll grab the latest version. This is the least popular as it's annoying but the option recommended by Corel for most people. Only recommending the patch if one of the bugs they introduced bothered you.
