create video file
edinbro
create video file
Post by edinbro »
after capturing via firewire, and editing etc. with VS9, do I save the result as an avi or mpeg2 file before burning it to dvd ?
thanks
stoney
erock1
Post by erock1 »
You would render (save) the .avi file(s) you captured and edited to mpeg2 for use as a DVD.
edinbro
Post by edinbro »
Thank you for your prompt reply erock1..I was saving (sharing) the finished file as DV avi which was HUGE (20 gig) and then saving it again as an mpeg 2...DUHHHH
stoney
Post by Trevor Andrew »
How long is your video
At 20 Gb using Dv-Avi it looks about 1hr 30 Mins
Converting to Dvd (mpeg) using the standard template at 8000 will be to large a file size to fit a dvd unless you reduce the bit-rate.
What country are you in Pal or Ntsc?
Trevor
edinbro
Post by edinbro »
I live in Canada therefore it is NTSC and when I burn a DVD I use fit and burn and it seems to work OK
stoney
Post by Black Lab »
Have a look at the sticky post at the top of the forum. To most experienced users of Video Studio you are following the correct procedure. It may seem that you are taking an unnecessary (and time consuming) step but, in reality, it saves you time and aggrivation.
edinbro
Post by edinbro »
Thank you ALL for your help...it is a time-consuming but VERY rewarding
hobby..and with VS9, after a few mistakes...the results are extremely satisfying
stoney
