Fade-in
Weeination
motherboard: ASUSTeK COMPUTER INC. K30AD_M31AD_M51AD_M32AD Rev
processor: 3.20 gigahertz Intel Core i5-4460
Video Card: Intel HD Graphics 4600 [Display adapter]
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Samsung SyncMaster [Monitor] 22.0
Corel programs: VideoStudio Pro X8
Fade-in
Post by Weeination »
What is the best way to have the beginning of a video clip fade-in from black to full visibility over the span of approximately one second?
If it matters, I already used the Brightness and Contast filter on that same clip. I also split the audio from that same clip. It is still there in the voice track but I used the audio filter to lower the volume to match the volume of the preceeding clip.
Re: Fade-in
Normally I just insert a black panel at the beginning of the video, then insert the video. You can either set an automatic crossfade transition in Preferences > Edit and set the transition duration to 1 second; or else you just drag the video over the end of the black panel for the period you want and this manually creates a crossfade transition. The black and other panels are located up to the immediate right of the top of the preview screen -- see attached screenshot.
Weeination
Re: Fade-in
Thanks for the help Ken. That worked great.
