The new 2023 version being 64 bit only is a problem here...
I want to continue using PSP., so...
Is there an address from where I can download PaintShop Pro 2022 32 bit?
Arturox
So PSP 2023 is 64 bit only?
- arturox
- motherboard: Yes-very-bored
- processor: 3-90 gigahertz Intel Core i3-7100
- ram: 8 Gigs
- Hard_Drive_Capacity: 250Gb SSD+1 Tb SSD
- Monitor/Display Make & Model: Acer 22 inch
- Corel programs: PSP 9-01 and PSP 2022
- arturox
- ram: 8 Gigs
Re: So PSP 2023 is 64 bit only?
Eventually, after some Corel Live chat, I obtained a copy of PSP2022.
We shall see...
Ax
We shall see...
Ax
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Why is 64-bit only a problem? Plugins?
- arturox
- ram: 8 Gigs
Yes, Plugins are the problem, which is why I've installed the 32bit version of PSP 2022.
Arturox
One really weird thing I noticed with the trial version of 2023 (now uninstalled) and even with the PSP 2022, the installer sprays files all over the place, in the most unexpected places... A bit like a mechanical manure spreader.
Ax
- arturox
- ram: 8 Gigs
Not something I've really thought about until now as I've always installed 32bit versions of PSP, and thus just transferred my Plugins to the new version.
Are there many 64 bit conversions of old Plugin favourites available these days?
Ax
Ax
- ram: 6 GB
The only conversions are from plugins still under development. Otherwise you need to use some kind of workaround. Like the bridge plugin from Mediachance. That plugin calls an external application that can run 32-bit plugins. There are also newish plugins that can do some of the things older plugins used to do. Like the G'mic plugin has a ton of effects it can run
Cassel
- ram: 16Gb
- Corel programs: PSP 8 (JASC) to PSP 2023
I have found one plugin bridge (not free). I wrote a post about it here:
https://scrapbookcampus.com/2022/10/fea ... ginbridge/
Cassel
- arturox
- ram: 8 Gigs
That's something worth knowing for the future if I ever decide to update past PSP2022.
Ax
Ax
