I say this as each time I try running PSP 2023 on PC I get the pop-up
"Warning Your System does not meet the system requirements for this application. I you continue you accept that Corel provides no guarantee or technical support...." popup
- I'm hoping the community could offer some other solution/answer to my question
(It seems I'm one of the many users that have trouble upgrading to Windows 10 - always failing @ ~70% of the installation for some reason)
Anyway, when trying to update to Win 10 I somehow ended up in a boot loop so to fix PC I had to use "Windows Recover" & do a 'Refresh' meaning my Programs were removed which in turn meant I have to reinstall them all.
Like an idiot I somehow forgot to make a copy of my PSP2020 installation files at the time or to register it even so there seem to be no records on my Corel account of my ownership ( DO have a receipt for the payment of it so I know I did own it legally)
Getting back on subject.
I thought this would be good time to update my software so purchased PSP2023 (& videostudio bundle) - not actually looking at the Min Specs (BTW my PC HARDWARE does meet the specs it's just the OS that's wrong - I'm Win 8.1 64-bit while Win 10 64-bit v1903 is Min)- and now when starting I get the warning popup mentioned above
When I search for a possible solution for stopping this popup from showing on start-up - I found a post on these forums stating to TURN OFF 'compatibility mode' will stop it (BTW the post was actually for PSP 2020 & Windows 11)
Checking my shortcut & I find the compatibility mode was already turned off however I thought I'd try "Run compatibility troubleshooter" anyway as an experiment to see what'll happen
Here's the thing
- IF Compatibility mode is set to "Windows Vista (service pack 2)" the Warning popup stops showing up when starting PSP 2023
Any other compatibility mode above this (Windows 7/Windows
After all this background info - my Question is - Why ???
Why is it that "Windows VISTA" is deemed compatible with PSP 2023 but Windows 7 & 8 are not
Is there anyway to prevent pop-up when NOT in compatibility mode, am I "losing" anything while running in 'Vista' mode
Any help appreciated
