Hiya, I'm a graphics newbie, and I'm following this tutorial : https://photoshoproadmap.com/give-your- ... ok-effect/
I know the tuorial is Adobe but does PaintShop Pro 2019 have a film grain filter or effect?
Regards
Dave
Is there a film grain effect
davediamond
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: Is there a film grain effect
Hi davediamond and welcome to the forum.
Try Effects - > Artistic Effects -> Halftone
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
The tutorial is for the halftone effect, not film grain.
If you want a real film grain, try G'MIC:
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
You can also simulate it by creating a top layer, fill it with black, set it to screen, and add noise to the layer Image -> Add/remove noise -> Add Noise
Then you can change the opacity of that layer to decrease the appearance of the added noise.
Hello,LeviFiction wrote: ↑Sat Oct 15, 2022 9:08 pm You can also simulate it by creating a top layer, fill it with black, set it to screen, and add noise to the layer Image -> Add/remove noise -> Add Noise
Thank you for your advice. It is really very practical.
warwickjensesn
- motherboard: Intel
- processor: Intel i5
- Hard_Drive_Capacity: 320
- Monitor/Display Make & Model: DELL LED
- Corel programs: CorelDRAW
TBH, This is very effective advice I tried it. Also this tutorial is also fine https://photoshoproadmap.com/give-your- ... ook-effect....LeviFiction wrote: ↑Sat Oct 15, 2022 9:08 pm You can also simulate it by creating a top layer, fill it with black, set it to screen, and add noise to the layer Image -> Add/remove noise -> Add Noise
Lime
- Corel programs: Paint Shop Pro 2022
I would like this too. I went to g’mic, and the program choices were Photoshop, xNPhoto, and Affinity. It doesn’t say anything about PSP.
Is there a reason for this?
I have other 8bf filters ( most of which do not work now) and I wondered how hard it would be to get this G’mic Film Grain up and running, and if anyone could provide instructions?
Noise is only ok. I used to have a film grain filter, and noise just seems a lot harsher and faker to me.
- ram: 6 GB
@Lime - https://gmic.eu/download.html
When I scroll down I see "G'MIC-Qt plug-in for
Photoshop / Affinity Photo / PaintShop Pro /
PhotoLine / XnView (8bf)"
Which does list PaintShop Pro.
Getting up and running is easy.
1) Find or create a folder to put the plugins. I put mine in the same location as all of the other files C:\users\username\documents\corel paintshop pro\20xx\Plugins
2) Download the G'Mic plugin, making sure to download the appropriate x64 or x86(32-bit) version and NOT the arm versions - here is the direct link to the download file. https://github.com/0xC0000054/gmic-8bf/releases
3) Unzip into your plugins folder
4) Add a custom plugins folder to put the G'Mic plugin in
a) File -> Preferences -> File Locations
b) Select "Plug-ins" from the list on the left and on the right click the "Add" button
c) Navigate to your created folder from step 1 and add it
PSP should now find the plugin automatically. If not, try restarting PSP.
Lime
Hey, thanks! I was on a different page and didn’t see any reference to PSP. (https://gmic.eu/reference/installing_th ... hosts.html)
You may have helped me solve a little mystery, too. I upgraded to 2022 and I thought filters were like scripts - you put them in the folder, and PSP auto-finds them. (I didn’t know you had to manually add them.)
Thanks, Levi!
Thanks, Levi!
