"Save All Open Images and Close" Command in PSP2021??
drhansenjr
- ram: 16 GB
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: HP Probook Built-in laptop monitor
- Corel programs: PSP Ultimate 2021
Is there any kind of menu option or simple script snippet equivalent to a"Save All Open Images and Close" command in PSP2021?? Same filename, same location. I frequently work with a large number of files open, typically modified by a script, and it is incredibly tedious, after the modifications are made, to have to go back through the files one at a time to simply save and close them.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: "Save All Open Images and Close" Command in PSP2021??
I think the closest direct command is Window -> Close All. If the image has changed and needs to be saved it'll ask which files you want to save, and then, if needed, pop up the save as dialog or just save the changes. If it doesn't need to be saved it'll just close.
If this is insufficient, or you need it all to be done silently, I'm sure a script exists somewhere but I don't think it's needed if Close All exists. Could even make one if no one knows of an existing one. It sounds very easy.
