briveira Its strange.....
I use Video Studio 2022 with my own projects MTS and MP4 video
I also test user samples provided through this forums.
Very, very rare that the program crashes.
What have you done to fix these crashes?
Some users find deselecting the Acceleration options reduces crashes, go to (F6) preferences – performance tab.
Have you tried resetting the program by renaming the folder “25.0” to “25.0_old”
C:\Users\UserName\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)
Also Re-setting the library from Settings – Library Manager.
If you need the library as is then first try Export Library to save a copy.
VS 2022 ultimate SP2
Pepi
- motherboard: ASUS TUF Z270 MARK 1
- processor: Intel i7-7700K
- ram: 32GB
- Video Card: AMD Radeon RX 5700 XT
- Corel programs: VideoStudio 2022; PaintShopPro 2022
Re: VS 2022 ultimate SP2
Just made a small trace, and my VS2022 25.1.0.472 is going to URL:
https://dwnld.videostudiopro.com/VideoS ... cation.xml
And that XML is offering only the SP1.
Perhaps they have found so serious bugs on SP2, that they have pull it back to factory
Don't Panic
Don't Panic
- RobertOZ
- Hard_Drive_Capacity: 7 TB
SP3 will be released,hopefully within a few days, which will include the Hotfix for SP2
SP3 has now been released, I found it via Check for Updates, I'm sure it will soon show as an auto update.
Installs to Version 25.3.0.584
And so far it seems to have corrected the problems with the earlier update which we had detected. Taken quite a while to get here, though...
I was amused, though, when the update went through the now usual process of having the progress bar go over to the right in about 1 second, and then sit at the far end for just on a minute in this case, before the update ended.
