I have VideoStudio 2022 Ultimate.
Every single tutorial on how to do split screens in VideoStudio has clips start at the beginning of the video. I'm creating a video which starts normally but then somewhere in the middle I want to split the screen between two takes of the same subject (two cameras were used to capture a rock band playing a song). When I drag a template on the storyboard where I want the split screen to start, whether pre-existing or a template that I create, it doesn't come with placeholders to replace with actual clips. So I have no way of telling VS which clip should go in which "frame" of the split screen.
When I learn how to do that, then I assume I'll have issues with timing the clips together... I intend to use the audio from one of the cameras in the voice or music track for that and mute the actual clips, but I'll still have to sync the videoclips with the sound.
Any help with this would be appreciated.
Split screen issue
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Re: Split screen issue
VS by default adds a split-screen at the end of the VSP. One way to move it where you want it, is to add a blank image as a placeholder on the video timeline where you want the split-screen, and then drag the images and splitlines.png to underneath the blank image (see image). tletteralbol wrote: I'm creating a video which starts normally but then somewhere in the middle I want to split the screen between two takes of the same subject (two cameras were used to capture a rock band playing a song). When I drag a template on the storyboard where I want the split screen to start, whether pre-existing or a template that I create, it doesn't come with placeholders to replace with actual clips. So I have no way of telling VS which clip should go in which "frame" of the split screen.
Consider creating a short project of your two recordings, creating a split screen effect if you wish
Sync your video files.
Render to a new video file, you can now add this new video to your main project.
You can also add the VSP to your project ( nesting) although I think rendering to a new file may be best.
When inserting the video to the middle of your project you may need to use Ripple Editing, depends on the content of your other timelines
