Corel FastFlick 2021 crashes after selecting theme, adding photo media and pressing the T button.
FastFlick 2021 has stopped working.
VideoStudio work fine.
Matt
I have modified your post to use Jpeg images, the forum finds these better to handle by showing as a smaller thumbnail, then selecting will show in full size.
Can I ask that in future you use Jpegs, cheers
Corel FastFlick 2021 crashing
Matt_06
- Corel programs: Videostudio 2021
Reason: resized images as jpeg
Re: Corel FastFlick 2021 crashing
Hi Matt_06
And welcome to the forums
I have used Fast Flick in the past although not used the “T” text options, I usually continue to edit the project back in video studio. ( Save and Share – Edit in Video Studio)
I have tested this and have no problems when choosing the “T”
I was using 16 still images, I notice your attached image used just one clip, would that be an image or video, looks like an image?
I cannot replicate this crash so difficult to suggest a solution other than to ignore the “T” within Fast Flick and edit back in Video Studio.
If using a Video can you try using the Sample_Lake, you should find that file here
C:\Program Files\Corel\Corel VideoStudio 2021\Samples\Video
As I say I usually edit the titles back within Video Studio
Still a bit worrying why it should crash.
PixSmith
- processor: Intel i3 CPU 550 3.20GHz
- Hard_Drive_Capacity: ARLINGTON
- Monitor/Display Make & Model: HP w2207h
- Corel programs: PaintShop Pro,PhotoMirage, AfterShot Pro
For what it's worth, I have this happen from time to time as well, but I can't figure out any particular rhyme or reason.
I would suggest opening a support ticket with Corel, but I am currently in my second (maybe third) month of tautological emails with them, none of which have even started to even address the issue. Your best bet may be here.
I haven't noticed any particular reason for the crash when using the "T" tool. I've had it work and not work on exactly the same project, so I think it's got to be some particular alignment of the stars (and windows resources) that causes it, but I haven't doped it out yet.
I did find it easier on the whole to just edit the titles in VideoStudio after a while, but that's because I could jump straight to them, and it takes a lot less time.
Just wanted you to know, though, that it's not just you.
Cheers,
Cheers,
Thanks for that info
Can I ask how you open Fastflick, do you open from VS tools menu or your desktop icon.
Clearly It should not make any difference but you never know.
It is a little frustrating when we cannot replicate these problems, but then it would be to easy to fix.
