Script Name: VectorizeImage & VectorizeLayer
Download: https://drive.google.com/file/d/1l-W-2c ... sp=sharing
Just Script the - https://drive.google.com/file/d/1PAfS63 ... sp=sharing
Compatibility: PSP 9-2023
Requirements: Place in Scripts-Trusted Folder
Extra requirements - If you already have the selection To Path script you don't need to re-download Potrace. The Script-Only version will be just fine.
If you don't have Potrace and you downloaded Script Only version you need the Potrace program found here - http://potrace.sourceforge.net/#downloading
Description: This script attempts to use my selectionToPath script to vectorize a raster image. It does this by first decreasing the number of colors in the image. You can choose between 2 - 256 colors (smaller numbers are faster). Then creating a vector shape for each color in the palette. The end result should be a noisy approximation of your raster layer.
Simple shapes and colors are best, so flat graphics, not photos. And the fewer colors the better.
The two scripts are "Vectorize Image" and "Vectorize Layer". This process is destructive, so both scripts create a copy of your image to work non-destructively. The first one will merge all of the layers into one image and vectorize the whole image. While the second will create a flat version of your layer, vectorize that. Placing the final vectorized image onto a vector layer in your current image.
It's not perfect, and there are definite ways to improve the speed with additional command-line programs. But for now this is a good basic starting point.
PLEASE NOTE: I'm not kidding when I say keep the number of colors low. These scripts can take anywhere from 5-30 seconds per color. If PSP is acting particularly slow or the image is very large and you go for the full 256 colors you could be waiting a minimum of 21 minutes. That's not great. I recommend sticking to 10-15 colors max. I will work on making the scripts faster.
Scripts - Vectorize Raster
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
