PSP 2022 crashes
PSP 2022 crashes
The start up screen comes up and after a while, PSP crashes. Tried running as Admin as well - no luck. This has suddenly started happening. Have reinstalled twice now without any success.
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Re: PSP 2022 crashes
Try a reset:
https://forum.corel.com/viewtopic.php?t=67616
Cannot do that. Crashes soon after the splash screen. Cannot get to the reset option. Possible to try a command prompt option, if any?Jean-Luc wrote: ↑Sun Aug 07, 2022 11:09 am Try a reset:
Tried Shift + PSP icon click with mouse. No joy.
Kathy_9
- Hard_Drive_Capacity: 2TB
When you say "no joy" do you mean the reset didn't help or you didn't get the reset dialog box because sometimes it doesn't come up right away.
Also, sometimes just a restart of the operating system helps.
Jean-Luc
Got the box - still does not work. Still crashes.
Yes. Twice now. Still crashes.Jean-Luc wrote: ↑Sun Aug 07, 2022 4:23 pmDid you uninstall it with the appropriate tools?
https://forum.corel.com/viewtopic.php?t=52337
Jean-Luc
Did you install both versions?
Does it crash with 32bit or 64bit version?
Did you update recently the driver of your graphic card?
If so, could you reinstall the previous driver?
If not updated, verify if a new driver is available.
You need also to verify if you have the latest Microsoft Visual C++ Redistributable.
Did you install both versions? No - 64bit onlyJean-Luc wrote: ↑Sun Aug 07, 2022 9:04 pm Did you install both versions?
Does it crash with 32bit or 64bit version? - 64 Bit. Tried 32bit and that crashed
Did you update recently the driver of your graphic card?No.
If so, could you reinstall the previous driver?Tried previous one. Still crashes
If not updated, verify if a new driver is available.Using latest Nvidia driver for the card - card is about 18months old
You need also to verify if you have the latest Microsoft Visual C++ Redistributable. Yes. Using latest version
Have reinstalled PSP 2022 again. Now the screen goes upto the Welcome screen. Stays there for 2 to 3 seconds and then crashes. very frustrating!
Tried PSP 2023 Trial version - same issue.
Jean-Luc
Disconnected your internet connection and launch the program. PSP is trying to connect to Corel's servers. It could be the culprit.
Jean-Luc
Strange...
Something was modified on your system.
Did you upgrade recently from Windows 10 to 11?
Did you add or remove something (screen, printer, software, ...)?
Did you use CCleaner?
Did you upgrade recently from Windows 10 to 11? No. Moved a few months ago when PSP worked.
Did you add or remove something (screen, printer, software, ...)?No
Did you use CCleaner? No. Nothing like that
