Randomly stopping at one point in editing (also cuts off in rendering at same point)
gewb
motherboard: MSI Pro B550-VC
processor: AMD Ryzen 7 5700X
Video Card: ASRock Radeon RX 6650 XT
Monitor/Display Make & Model: LG 24MK430
Corel programs: 2018, 2021, 2023 Ult.
Re: Randomly stopping at one point in editing (also cuts off in rendering at same point)
Post by gewb »
JakeStone7777 wrote: Mon Aug 01, 2022 11:36 pm Would anyone be willing to let me give them the file somehow and try seeing if it happens on their end too?
Zip it (VSP) and upload it, I'll take a look.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
Untick here.
Any better?
Panasonic X900m, VXF1
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
JakeStone7777 wrote: It's only happening with this one clip from the iphone file.
Run your clip through a video transcoder and see if that resolves the issue.
tletter
JakeStone7777
Corel programs: Corel Video Studio
Post by JakeStone7777 »
Asik1: I tried that and it didn't help but thank you for the suggestion.
gewb: Thank you so much! I made a copy and zipped it. I believe it should be attached.
Team Rocket Love - Copy.zip
(17.65 KiB) Downloaded 55 times
canuck
operating_system: Windows 8.1
Post by canuck »
Which clip, at what time point?
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
Something is not quite right with the .vsp from 24.49 through to the end of that particular clip, if I move the scrubber to any point after that time but staying within that clip, then select play,the scrubber jumps to beyond the end of the project, but if I move the scrubber to the next clip then select play, the video plays normally.
Any reason why you have text in the overlay track and not the Title track
Also VS states, "These files cannot be added to the project"
JakeStone7777
It's 24:49-59. I didn't know it mattered if it was in overlay or title. Does it?
Thank you all for trying to help. I really appreciate it.
gewb
Post by gewb »
Found the problem but not sure WHY it was a problem. Also found a potential minor problem. Both involve your voice track.
The freeze up around 24:49.027 will go away when you delete the short "whistle" cut on the Voice track at 25:00.024.
A potential problem is a one frame clip on the Voice track at 26:27 as this forces the project length to extend that far even though the images and music stop seconds before.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
Good finds gewb, orphan frames are culprits in any NLE.
The shortcut CTRL+H or CTRL+E will jump along all project segments and can be used to find orphans...
RobertOZ
Post by RobertOZ »
Confirmed, removing that orphan frame at 25.00.024 resolves the problem
JakeStone7777
THANK YOU ALL SO MUCH!
shimbim
motherboard: MS Surface Pro 8
processor: i7-1185G7
ram: 16Gb
Monitor/Display Make & Model: LG 24EN33
Corel programs: VS20, PSP20
Post by shimbim »
Hi, I had exactly the same thing. I do not know how i fixed it but i think it relates to the clip which FOLLOWS the one it is stopping at (which is why it continues to be a problem even when you remove the clip). i wondered if it was something to do with accidentally changing time mapping but not sure. i think i fixed it when i removed the subsequent clip. Hope this helps,Tim
zaphodikus
motherboard: ROG-X570-F-Asus
processor: AMD 3950 - 16 core
ram: 64Gb
Video Card: AMD RX 6700
Hard_Drive_Capacity: M2 1TB
Monitor/Display Make & Model: 4K BenQ
Corel programs: VS 2023 Ultimate, Painter 2020
Post by zaphodikus »
a bit late, but yeah MOV files are a problem have had pain with VS playback or render being borked or just stopping if I have MOV files in timeline. Convert using ffmpeg if that's happening to you and you don't need MOV container for some other reason like using MOV as a mask.
