Problem Importing MTS Files into Video Studio 2021
Re: Problem Importing MTS Files into Video Studio 2021
Thanks Rob
I am also having the same problem opening those MTS samples.
So far I cannot see any difference with those and my own other than I have Surround Sound and your samples are using Stereo
You can probably ignore the K Lite
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
Can import to timeline OK , but no video or sound, looking at the properties, appear similar to other samples, so is there something with that particular camera that's causing the issue
RobertOZ
Post by RobertOZ »
Ok, now have 00126.mts displaying in timeline, all I did was use HD Video Converter to convert to .MTS, touched nothing else
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
This is what VS-X9 report on the 20.mts
VS 20 or 22 do not open it at all.
**VMS16 or Vlogger open the file just fine.
Panasonic X900m, VXF1
RobertOZ
Post by RobertOZ »
Magix Movie Edit Pro Premium 2021and Adobe Premiere Elements can import and play the original files without issue
Hi Rob
There was a post by you on March 18th 2021 just a year ago for the same problem.
https://forum.corel.com/viewtopic.php?p=386452#p386452
your post and replies are identical to this post.
Some replies referring to the Panasonic cameras set up and reference to the HD Writer.
Did you check the cameras settings and or reset those to factory set.
It is a possibility that Video Studio is seeing the files as being copyright protected,
Cybernick replied….
“Can it be something with HDCP protection enabled in the recorder?
In any case I would suggest to install k-lite to your PC if you do not have yet.”
The recent reply here by RobertOZ, after using HD Writer would suggest to me that you use that software to transfer the files from the camcorder to the pc, if that process is successful then there will be no need to convert the files, Thanks for that Robert, although I do own a SD 900 camcorder ( away being mended) I never received the HD Writer software.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
https://av.jpn.support.panasonic.com/su ... _ae54.html
* I see the OP files are 1080/50P 25Mbs, I never shoot that high for practical reasons.
Are only those 2 have the culprit ? or the full SD ?
I own a hdc sd 900 panasonic, records to same as Robs cam, as far as i can tell. My cam is away being repaired.
Recordings done as auto uses 1920 x 1080 x 50p, we can choose a manual setting as 25 fps but uses interlacing UFF
Video Studio is a bit slow editing mts types, but does cope better with progressive 50p fps.
Just importing mts to video studio is much slower than importing similar mpeg4 files
So when i burnt bluray i had to use 25 and interlaced, if i edit for pc playback or tv but not bluray then 50p seems the best option
Whatever settings i have used the video has never failed using Video Studio.
And as far as we have been told the problem affects all recordings not just the 2 samples?
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
OK.... So I took my VXF1 and shoot 2 short 1080 50P clips.
All my VS's import and play them correctly.
*** Oh... I do have K-lite 16.0.5 basic installed
Rob's is on left, mine on right
Direct D/L my 64.mts
https://tinyurl.com/5annk8y6
RobCharles1981
motherboard: MSI MAG B650 TOMAHAWK
processor: AMD Ryzen 7 7800X3D
ram: 32gig DDR5
Video Card: XFX 7800XT
sound_card: Sound Blaster Z
Corel programs: Studio Ultimtate 2023
Post by RobCharles1981 »
Hi - all sorry for the late response - ile keep an eye on this and will update when possible!
