As you've stated that the colour issue is restricted to VS, then perhaps the issue is caused by a setting in VS. Try opening into the Preferences dialog (Press F6 on your keyboard, or Setting -> Preferences), go to the Edit tab, and ensure that the "Apply Color Filter - NTSC/PAL" is unchecked.bwalton wrote: ... the raw video displays fine in VLC but loaded in VS red displays as blue
I can only suspect its some sort of setting on my end but I cant fathom what it could be.
As issue affects both VS2018 and VS2022 straight out of the box, then it'd be worthwhile to check your codexes.bwalton wrote:I downloaded and tried 2018 and its the same.
tletter
