Cannot cut a video with UVS9
Nounours18200
Post by Nounours18200 »
I have a small video (1,9Gb) to cut in two parts of approximately 4mn43sec each.
When I start the cutting process (starting at 0mn0sec, ending 4mn43sec), it runs fine until 99%, and then UVS9 reports the following error:
Not enough disk space on this drive. Try to write on another drive or reduce the size file. [17117:29:1]".
But I have 25Gb of free disk space on the drive C:, and 40Gb free on J: (which is defined as the working directory in UVS9). All the disks are NTFS. Ihave tried to use another drive, it does the same error...
Any idea ???
N.
P.S.: I use XP Pro-SP2 (French) with all patches installed, and UVS9 French with Patch 1 installed.
AnimeChick
Post by AnimeChick »
How exactly are you cutting it. Just cutting the video on the timeline should not require additional disk space.
Nounours18200
I translate the actions in English herebelow, startin from a new project:
File/Insert a Média File in the timeline/insert video/ my own .avi file
Then I click on the "multi-cut video button" (if the English name is the same), I mean the last left down button on the left side on the screen.
Then on the pop window, I select the "start point" , I select the "end point", and I click OK.
The video is correctly cut in the timeline.
Until now , no pb.
The pb comes when I do: "Clip / Save the cut video": UVS9 starts to save the cut video on the disk up to 99%, and at the end, it generates the "not enough disk space" error message.
But the funny thing, is that it has correctly saved the cut video ! after having click on the "OK" button of the error message, I see through the windows explorer that the file has been correctly generated...
So despite the error message, I get my cut video and can continue to work.
I have the same version of UVS9 installed on my notebook (also using XP-SP2), and I do not have the pb on this machine...
Any idea ?
