https://kb.corel.com/en/128877
Symptoms
After installing VideoStudio 2022, you are prompted to login to or create a new user account. The screen presented is malformed and cannot be used to input your credentials.
Cause
There is damaged information within the Messages folder that requires a cleaning to be performed.
Resolution
1) Right click on the start button
2) Choose Run
3) Type %appdata% and press Enter
4) Open the folder labeled Corel
5) Open the folder labeled Messages
6) Press CTRL+A to select Everything in the folder
7) Press Delete to send them to the recycle bin
After this is done, try and launch VideoStudio.
Did this solution work for everyone? Who else had problems before this - and how did you solve it?
