Lightning area in photo?
ralphedel
Post by ralphedel »
Is it possible to lighten an area in a photo, not the entire photo which I know how to do? For example, if one face is a bit dark or low contrast, can either or both of those be modified without changing the entire photo? I do not see anything describing how to do that in the manual or anywhere on-line. Many thanks.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: Lightning area in photo?
Post by Jean-Luc »
Try the Darken/Lighten Brush.
If the subject is more specific, post it here and we could provide more precise advice.
Read also this discussion:
https://forum.corel.com/viewtopic.php?t=63551
GEAK
processor: i5-2320
Video Card: NVIDIA GeForce GTX 950
Hard_Drive_Capacity: 2TB
Post by GEAK »
ralphedel wrote: Sat Jun 18, 2022 7:52 pm Is it possible to lighten an area in a photo, not the entire photo which I know how to do? For example, if one face is a bit dark or low contrast, can either or both of those be modified without changing the entire photo? I do not see anything describing how to do that in the manual or anywhere on-line. Many thanks.
There's a couple different ways, this is the method I prefer using.
  1. Duplicate the background layer
  2. Adjust the duplicate (via adjustment layer or just directly adjusting the brightness & contrast) to correct the area you want to adjust
  3. If you used an adjustment layer, merge it with the duplicate
  4. Apply a show all or hide all (depends on whether the adjustment area is bigger or smaller than the rest of the image) mask to the duplicate layer
  5. Use black & white paint brush on the mask to hide/reveal only the parts of the adjusted layer that you want
