- If VS is opened by selecting a project (*.VSP) rather than via the Start Menu, LUT.profile is not affected regardless of whether the library is viewed or contains an element with a LUT applied. This seems a bit curious to me.
- Perhaps less surprisingly, if an element in a project has a LUT applied, the LUT will be applied even if the LUT is no longer listed in the library.
To date, I have not had any issues related to my temporary workaround (setting LUT.profile to Read Only), other than needing to remember to switch it back to Read/Write if I need to add or subtract any LUTs from the library. I strive to keep the number of LUTs limited as VS can get very slow to load the library as more LUTs are added because it has to rebuild each of the LUT icons (which suggest the nature of the color shifts) the first time the library is opened in any new session.
