I copied WEBP Plugin from http://www.telegraphics.com.au/sw/product/WebPFormat
into folder
PSP\MyPSPFiles\Plugins\WebPFormat\
How can I find out if this plugin in successfully/registered recognized (in PSP X2)?
When I drag &drop *.webp files onto PSPx2 then an error popup appears:
"The specified file cannot be identified as a s supported type"
is it because the Plugin does not work or because the *.webp file is damaged?
How to find out if plugin recognized and active?
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Re: How to find out if plugin recognized and active?
I think PSP X2 doesn't recognize the .webp file format. This format didn't exist when X2 was created.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
pstein - since the webp format plugin you downloaded is an .8bi plugin check to see if webp shows up in the extensions list in the open file dialog. File -> Open.
If the extension were .8ba I would tell you to look under File -> Import.
If the plugin has loaded properly it'll show in the extensions list.
