Hey. Sorry for so many questions in regards to 2022. Just need to clear some stuff up before I potentially buy it.
So I currently use Pro X7, mostly for an animated Youtube show. It works unusually well for what I use it for. (https://youtu.be/g8xh-pj4jmk?t=10 just an example)
One of the things I use a lot is custom motions. X7 has an option for ""Show Result in Preview Window". Which allowed you to scroll through the actual project as you edited the motion. This was incredibly useful as you could leave markers on the timeline as reference points on when to change the motion of the video/image, and then line it up in the custom motion window. However in 2022, this option is seemingly gone and now everything is a lot more complicated to do in regards to timing.
I understand this is oddly specific but, is there any way to use the ""Show Result in Preview Window" in the 2022 version or am I just out of luck? I'll attach an image to try to clarify some things.
"Show Result in Preview Window" gone in 2022?
TheLonelyGoomba
- Vendelin Zatko
- motherboard: Asrock B450 PRO4 R2 soket AM4
- processor: AMD Ryzen 7 3700X 8 Core Processor 3 60 max 4 20
- ram: 32 GB DIMM
- Video Card: N Vidia GeForce GTX 1650 4GB RAM
- sound_card: onboard Realtek R audio
- Hard_Drive_Capacity: 1T SSD 5T HDD
- Monitor/Display Make & Model: Samsung T55 HDMI FHD 1980X1080
- Corel programs: UMSPro 6-7-8 PhotoimpactX3 VS 2021 2022
Re: "Show Result in Preview Window" gone in 2022?
Hello. You're right I worked in X6 before then X8 worked there. It does not work with regret in VS 2022. I miss it too !!!!
