1. Source video: Ulead Video Capture via Canopus ADVC-100 (firewire DV) of a VHS tape of a wedding shot with lousy equipment by the church itself.
2. Capture settings: DV type-1 (a mistake?); saved as approx 6 GB AVI (approx 30 minutes)
3. Audio problem: terrible AC (60 Hz) hum throughout. Media Studio Pro filters do nothing for this.
4. Solution, based on reading this forum: clean up the audio in the open source Audacity program
5. Problem: resulting audio will not synch exactly
To get the audio into Audacity and back into MSP:
1. I opened the audio in Ulead Audio Editor – because Audacity could not open the AVI file (over 10 minutes and ate up to 1GB real and 1GB virtual memory before I killed it).
2. Saved as WAV (PCM) 44.1kHz, 16bit stereo. I tried saving as WAV DV-Audio NTSC, but Audacity crashes with this format.
3. Opened WAV (PCM) in Audacity, removed noise, saved as WAV (PCM only option).
4. Opened WAV from Audacity in Ulead Audio Editor and saved as WAV DV-Audio NTSC (you’ll see why)
The screenshot below shows the original, synchronized AVI audio track on top, the WAV (PCM) audio track in the middle, and the WAV (DV-Audio NTSC) at the bottom.
You can see that the WAV (PCM) has drafted considerably. 25 minutes into the video, the sound is delayed 0.6 seconds. While a small percentage, the result is unusable.
Converting the WAV (PCM) to WAV DV-Audio NTSC in Audio Editor puts us only 3 frames behind the action at 25 minutes into the video, a delay of only 0.1 second, but still enough that watching the lips and sound is disappointing.
I’d appreciate any help in understanding what workflow to use to avoid sound drift like this. Given that the Ulead Audio Editor component of Media Studio Pro 7 has WAV as the least-compressed output format … and simply opening an AVI file and saving the file as WAV results in shrinkage of the length of the audio …I’m not sure what to do?
I understand the suggested workaround of cutting the clip into small sections – perhaps 10 minutes each and putting them back together again. But, there must be a workflow that doesn’t require this? (I would have to use the extra step of DVI-audio conversion even there to get perfectly locked on sound.)
Thanks for any ideas and suggestions!
Karl
