I enclose a bat file that will clear all unnecessary languages from VS2022 layout. If you are using only English you can gain back ~500MB!! (in your C: drive) by removing other languages translations.
Unzip to the desktop and run it.There is a pause on each step Be careful as deletion is final and do so at your own risk.
*You can exit at any point by click the X.
There are more files to be delete and you can edit the bat file in notepad and add more paths according to your personal VS installments.
** It shouldn't effect actual language text support, only the software menus.
Run it at your own risk
Remove languages from VS2022
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
- Attachments
- Only English VS2022_.zip
- (779 Bytes) Downloaded 68 times
Panasonic X900m, VXF1
