PSP locks files and folders after all files are closed
SJS
motherboard: Dell Inc 0KWVT8 A03
processor: 11th Gen Intel Core TM i7-11700
ram: 16 GB
Video Card: NVIDIA GeForce GTX 1660 Ti 6GB GDDR6
sound_card: Onboard Realtek Codec
Hard_Drive_Capacity: 4 TB
Monitor/Display Make & Model: DELL U2412M
Corel programs: PaintshopPro 2022 Ultimate
Post by SJS »
Paintshop Pro has a bad habit of not properly "releasing" a file after it has been closed. This prevents renaming or moving files using File Explorer.
It is necessary to close PSP in order to rename a file that I have been editing, although I have no files still open in PSP. Closing PSP releases the file and lets me rename it.
This has been a problem for me for several versions of PSP, but I don't recall if I have reported this before now.
Is this a known problem?
Re: PSP locks files and folders after all files are closed
FWIW I have just opened a couple of jpegs in PSP 2022. I left them for a little while, then closed them in PSP which remained open. I then went to File Explorer and renamed one and copied and pasted the other. Both of these functions worked and as I say, PSP remained open.
In other words, I cannot replicate your problem, unless I have misunderstood your workflow. And I can't say I have ever noticed it before with any version of PSP.
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
I've experienced the "locking" issue also but not just with PSP but also MS Outlook 2019. I usually notice it if I attempt to delete the file and I'm told I can't because it's open in (name of program). When that occurs and I close the program and still have the issue, I use a utility called Unlocker.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Do yose manage mode at all? And if you' do, have you added the folders these images are in to the cataloging side? Or is this only with editing?
Kathy_9
Post by Kathy_9 »
You are probably asking SJS but for my workflow, I never use Manage Mode; only Edit.
patara
motherboard: ASUS Prime Z690 DDR5
processor: Intel i7-12700K CPU 12 Core
ram: 32 GB
Video Card: GeForce GTX 1060 GI Gaming 6G
sound_card: VIA High Definition Audio
Hard_Drive_Capacity: 1TB SSD +22TB Hard Drives
Monitor/Display Make & Model: Dell U2715H
Corel programs: PSP7 to PSP 2023
Post by patara »
SJS wrote: Fri Apr 29, 2022 5:47 pm Paintshop Pro has a bad habit of not properly "releasing" a file after it has been closed. This prevents renaming or moving files using File Explorer.
I have that problem with PSP from time to time. I only work in Edit Mode. If refreshing my folder does not fix it, I right click the file or folder in question and use a free app called LockHunter.
In the dialog box that opens there are options to Unlock, Delete + other combinations.
Usually that sorts it out for me.
I've been using LockHunter on my system for many years. It is a handy app to have.
https://lockhunter.com/?ver=3.4.3.146&o ... _window_64
SJS
ram: 16 GB
Post by SJS »
OK, this is not just me. A PSP bug ... and now I have a faster computer, closing & restarting PSP is more reasonable... Thanks for the suggestion.
SJS
ram: 16 GB
Post by SJS »
The locking issue has often been with renaming the folder containing the edited & closed file. I never use manage, only Edit. I cannot replicate the problem at will either. Since I don't regularly attempt to move or rename files & folders after editing them, it is hard to judge the frequency. But it does seem to happen quite often, when I do try to do this.
I have tested closing every other app and I cant rename or move until PSP is closed.
