Incorrect Frame Rate
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
I normally shoot video at 59.94 fps, yet when added to the timeline, the properties are showing a frame rate of 29.97 fps
I tried just about every setting in Preferences and Project Properties but the result is always the same, problem also happens with VS2018 & VS2021
Must be doing something wrong, but can't figure out what.
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Re: Incorrect Frame Rate
Post by tletter »
RobertOZ wrote: I normally shoot video at 59.94 fps, yet when added to the timeline, the properties are showing a frame rate of 29.97 fps
Works fine in VS2018 when VS is allowed to match the properties of the video clip.
tletter
RobertOZ
Post by RobertOZ »
I do that automatically, but what's happening is when the media is added to the library, the properties show fps as 29.97 instead of 59.94, same if I add direct to timeline
tletter
Post by tletter »
RobertOZ wrote: when the media is added to the library, the properties show fps as 29.97 instead of 59.94, same if I add direct to timeline
  1. Added the 60fps file to the Library and its properties are correctly determined by VS (see LHS of fol image).
  2. Created a new project and dragged the 60p file from the Library to the TL, and VS correctly matched the file's properties (see RHS of fol image).
It might be worthwhile to check if some of your FHD 60fps files are corrupt in some way. Perhaps this could be done by transcoding one of the problematic FHD 60fps file into a FHD 60fps file, and then seeing if VS can properly handle the transcoded file.
tletter
RobertOZ
Post by RobertOZ »
Well. that was some exercise, first of all, tried HandBrake, tried various format options with a wide range of 59.94 fps clips, each time the resultant properties was given as 29.97 fps
Then tried WinX HD Video Converter, converting to .mov this time the correct fps is given and can be imported into VS with the correct fps.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
Robert why you shoot ~60 and not 50? you must have flickering.
Panasonic X900m, VXF1
RobertOZ
Post by RobertOZ »
Hi Adi,
Goes back to a time when I worked for an American Company, so using NTSC became the norm for me, I found some advantages (can't remember what they were now) so stayed with NTSC
Solved the problem with HandBrake, operator error (me)
