You've finally done it Corel.
Carnage
Post by Carnage »
You've made me SO &!$$ed at this janky software, I'll just learn photoshop. I've not bothered for like 6 years because I was familiar with PSP.
Congratulations.
SO 2-3 months ago, I was getting annoyed that PSP would not close down properly, I had to ALWAYS enter task manage and kill iit's process. Really?
Told to basically reset the software to fix it, lose all my settings etc...
Did it work? Depends on the day... still have to do it every so Often... but I really DO enjoy losing all my preferences to sort of fix it...
This new issue has been happening every so often, BUT.
Today, I'm making a SIMPLE image in 4K, that is for a metal reflective texture.
I take my base Image and greyscale it.
I darken/contrast it.
I open a different layered image (that is in 8K), unsee all but 1 layer, which has a texture with transparency I need. (some scratches, White will reflect light ingame, black will not reflect)
On my 4K image I make a new Raster, fill it white, create a mask from the 8K image displaying only 1 layer as Source Luminance.
Cool, now I have my darkened base image with a layer group which is 1 white raster and transparent mask on top, giving me the white scratches on the top of the dark base image.
I duplicate that layer group, turn off the original (because I want to keep if I need it later), and I merge the duplicate group into a single raster and leave it on, I then duplicate that raster again to make the white more prominent.
Simple right? seems like a REALLY REALLY SIMPLE, situation. I literally have 3 Rasters in the image, 2 have a lot of transparency, and 1 later group turned off on the image, I haven't even bothered naming the layers yet.
I save the layers as a .PSP.
I go to save a PNG version, as I need to convert this to a .DDS in another program.
CRASH to DESKTOP.
$%&# ME
I re-open the PSP version.
I delete the .psp and START AGAIN, I go through the process above again in exactly the same way, CRASH to DESKTOP AGAIN.
AGAIN the &%$#ing Runtime Error...
What the %#$& is the issue with this software?
This CRAP has been happening ALL WEEK whenever I'm using masks and layer groups.
I have reinstalled the %$@#ing Visual C++ Runtime Library, and I still get this $#!&.
HOW, HOW???? is this SIMPLE process SO $%&#ed in your software?
I don't wanna spend 30 minutes trying to make the same 3 minute image trying to navigate around whatever the hell is with your mask layer, or Alpha or layer groups... or whatever the %&#$ it is creating a %^&#$ C++ runtime error.
I don't need anyone to try and fix this, I'm &%$#ing DONE with this $%*#.
You've finally made me a convert to Adobe AGAINST MY WILL, that is how utterly sick to death of this I am.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: You've finally done it Corel.
Post by Jean-Luc »
Be sure Save edit history is unchecked.
See this post:
https://forum.corel.com/viewtopic.php?f=56&t=69077
and the paragraphs about Preferences saving and History saving.
Do you have enough memory (your profile is not complete)?
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Why would this make you go to Adobe? If you're gonna spend that kind of money I would look into any of the tens of free or more affordable quality software available vs Adobe. You are correct that it should not be happening.
Also, why are you deleting the PSP every time? A pspimage file should hold all of your edits so you don't have to start from scratch.
splash3313
Hard_Drive_Capacity: 1tb
Post by splash3313 »
For one thing it looks like you have installed psp on an external drive h. Now we don't know the version of programs you are using windows and psp. Firstly your post points to you useing an external drive. Secondly are you using the latest psp and do you have the latest windows updates. Runtime errors are not psp fault actually Microsofts . It could also be a driver fault on your PC so update them if you can.
splash3313
https://forum.corel.com/viewtopic.php?t=41272
I know its video studio link but runtime errors usually indicate faults of hardware and memory
jukka
System_Drive: B
processor: thunderbolt
ram: 32bmw
Video Card: s3 triodent
Monitor/Display Make & Model: whaat?! 4 monitors. Yup! 4
Corel programs: psp 2020, videostudio 2019
Post by jukka »
funny that your app cannot close.
Mine psp 2020 cannot start. Same process, have to start, kill the process and then start again.
splash3313
Right If your having problems with any apps on windows tryu a check disk and if that does not work try a sysfc /scannow at command prompt as long as you set the command prompt to adm
If your getting runtime errors delete and reinstall said runtime. The reason your getting errors is that microsoft have altered something in that runtime or its corrupt.
