Ctrl + D
Shortcuts should show next to the item in any menu. Here you can see the Selections menu and to the right of each command is a shortcut key combination to activate it if you don't want to use the menus.
If no shortcut keys are showing that might mean that no shortcut is assigned to that menu item. This can be a result of the workspace being corrupted, though since you recently reset it hopefully that's not still the case.
Woodgrain effect?
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Woodgrain effect?
Jane_Doe00
- motherboard: AMD A10
- processor: AMD A10 5750M
- ram: 16gb
- Video Card: 3gb Nvidia
- sound_card: High Definition Beats
- Hard_Drive_Capacity: 250gb
- Monitor/Display Make & Model: Hp 15 Inches Hd Display
- Corel programs: CorelCAD
If you have Paint Shop Pro X then this is how.
1. open the image size you required.
2. Flood fill the image with color you require.
3. find Effects/Texture Effects/textures...
4. in the Texture box, click on the arrow to open Texture options.
5. scroll down to the bottom until you find wood grain(note the others textures)
6. change the image and light settings if you want.
7. click ok.
8. to make a seamless tile find Effects/Image Effect/Seamless tiling...
9. change the value until you have the effect you require.
10. click ok when done.
Now you should have something that looks like wood grain.
I think you should have follow these steps for making woodgrain effect.
7. click ok.
