Woodgrain effect?
Kathy_9
Hard_Drive_Capacity: 2TB
Re: Woodgrain effect?
Post by Kathy_9 »
That is very strange. I've never seen that happen and the trial should not have anything to do with it. Try doing a reset to default.
Here are the instructions: https://forum.corel.com/viewtopic.php?f=56&t=67616
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
legepe wrote: Thu Mar 03, 2022 4:34 pm Im in complete workspace, Ive just tried essentials and gone back to complete but no different?
Try this:
legepe
Corel programs: PSP2022
Post by legepe »
Thank you both for this possible solution, but I do not have this option to select a reset in file/preferences, this is missing as well as file location???
I can see that there should be 7 options in preferences, but I only have 5 (and this is on both computers)
Also, I can see from Jean-luc picture, Colour Management and Database backup is missing in File?
Kathy_9
Post by Kathy_9 »
Okay, two thoughts.
1. Make certain you are really in the Complete workspace and not the Photography workspace. Note: Photography has only 5 options in preferences and not 7 like Complete.
2. If you truly are in the Complete workspace you can reset by holding down the shift key while starting PSP from the desktop icon. It's detailed in the instructions I linked to earlier.
legepe
Post by legepe »
Ok, thanks Kathy, that fixed the missing things to select in File and Preferences
I have put picture files into Textures and can see them in Material Properties, but I need this to be able to use in Effects - Is this not possible?
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
legepe wrote: Thu Mar 03, 2022 6:53 pm Ok, thanks Kathy, that fixed the missing things to select in File and Preferences
Which of Kathy's suggestions fixed your problem - the Reset routine or were you actually in the Photography workspace, not the Complete workspace?
JoeB
Using PSP 2019 64bit
legepe
Post by legepe »
JoeB wrote: Thu Mar 03, 2022 6:56 pm
Resetting with the shift key fixed the problem of missing items, however, I still want to know if I can use my own picture files in - Effects and not in Material Properties?
Kathy_9
Post by Kathy_9 »
No, you cannot add to the built in Effects. You can however use your own pictures by linking to the folder it is stored in via File Locations - Texture.
Then once you have done that you can either access your texture via the Materials Palette or via Effects - Texture - Texture.
Kathy_9
Post by Kathy_9 »
Here's an example of a wood grain effect added to an image via Effects - Texture Effects - Texture.
Click for larger view
legepe
Post by legepe »
Kathy_9 wrote: Thu Mar 03, 2022 7:28 pm No, you cannot add to the built in Effects. You can however use your own pictures by linking to the folder it is stored in via File Locations - Texture.
If im correct I have now linked my picture file in File Locations - Texture
You have then said - "you can either access your texture via the Materials Palette or via Effects - Texture - Texture" however, I cannot access my picture(s) in Effects
Have I done something wrong?
and yes that is the effect i am trying to get!
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
When you open the texture dialog click on the texture picture to bring up the texture selector. THen make sure the category drop-down in the selector is set to "All" to see all images that PSP has found.
If it's visible in the materials palette under "Textures" not "pattern" it should be visible in the Textures selection in the Texture Effect.
legepe
Post by legepe »
Thanks Levifiction but in my case you are going to have to be very specific... I dont know, looking at your picture.. are you in Matierial Properties? I cant find where you mention texture dialog..! (after everything in this process of trying to apply an effect I feel like I am using another program)???
ram: 6 GB
This is the Texture Effect dialog. You find it by going to the menu at the top of the program and selecting Effects -> Texture Effects -> Texture
Here is a video demonstration of the two methods mentioned in this forum topic: https://drive.google.com/file/d/1nzff_J ... sp=sharing
It's not a great video, I didn't have much time. If the link still says "processing" you can download the video to watch it. Or wait for it to finish processing to stream it online.
legepe
Post by legepe »
LeviFiction wrote: Thu Mar 03, 2022 8:30 pm When you open the texture dialog click on the texture picture to bring up the texture selector. THen make sure the category drop-down in the selector is set to "All" to see all images that PSP has found.
Thanks for this.. My picture/image I have when sized to what I need completely greys out the picture but I feel that I may be on the right track now.. a bit of playing around with things/different pictures and hopefully ill get there!
legepe
Post by legepe »
Ive managed to do a reasonable job playing with the settings in the Texture Effect dialog. just one really quick question... Its really annoying.. What is the deselect shortcut?
