Video Studio 2022 Ultimate - Where is BorisFX
kmoulds
motherboard: Micro Star International Co Ltd MAG B660M MORTAR
processor: 12th Gen Intel Core i7-12700
ram: 32 GB
Video Card: 8192MB Radeon RX 590 Series
sound_card: Internal
Hard_Drive_Capacity: 16 TB total
Monitor/Display Make & Model: LG FULL HD (1920x1080@60Hz)
Corel programs: VideoStudio 2023 Ultimate
Post by kmoulds »
I upgraded from 2021 Ultimate to the recently released 2022 Ultimate and installed same.
However, for the life of me I can't find BorisFX at all. It is still offered I believe.
Any help would be appreciated. I have already created a ticket with Corel as their chat was overloaded.
Cheers Kym
Cheers Kym
RobertOZ
Hard_Drive_Capacity: 7 TB
Re: Video Studio 2022 Ultimate - Where is BorisFX
Post by RobertOZ »
Boris is no longer included in VS, not for the last few versions
Choi seong chul
motherboard: Asus Z390
processor: InteCore i9 9900KF
ram: 64GB DDR4
Video Card: NVIDIA GeForce RTX 2080 Ti 11GB
sound_card: MAYA U5 External Sound Card
Monitor/Display Make & Model: LED Raantec 24"
Corel programs: CVS X4,- X10,2018-2022,2023
Post by Choi seong chul »
To use Boris FX., you must have an earlier version with Boris FX.
Way
You must install a Video Studio program that supports Boris Graffiti. Video Studio X10 must be installed. (older versions work too, but X10 is better)
This will install the library for Graffiti. then
C: \ Program Files \ Boris FX, Inc \ Keyframe Libraries 7 \ Graffiti 7 Keyframe Library with BCC presets 10 Corel should appear. after confirmation
C:\Program Files\Corel\Corel VideoStudio X10\vft_plug
You can find Graffiti7.vft. And here is also BCCTitleStudio.vft.
copy that file
C:\Program Files\Corel\Corel VideoStudio 2021, 2022to \vft_plug
paste it.
And now it will appear and be available in VideoStudio 2021, 2022.
I've tested it and it works well for me.
RobertOZ
Post by RobertOZ »
Well it doesn't work for most, states trial mode only
Choi seong chul
ram: 64GB DDR4
I work very well.
RobertOZ
Post by RobertOZ »
Licensing laws could be different in Korea
Choi seong chul
ram: 64GB DDR4
In my experience, the Boris program is a bonus for video studios.
Reinstalling BorisFX manually solved it for me.
I have installed X10 version of GraffitiCorelX10x64.exe.
Although I do not have X10 installed it did create the X10 installation folder containing the vft_plug folder
I copied the Graffiti7.vft to 2021 and 2022 Trial both show in FX library in the Boris category appear to work ok.
I have not been as successful using Boris Title Studio, I think if I had the program installed then that would probably work.
RobertOZ
Post by RobertOZ »
Like you Trevor, Graffiti7 is installed in 2021 & 2022 and is fully functional, but BCC, copied from 2018,whilst installs OK, is in Trial mode only,
Choi seong chul
ram: 64GB DDR4
My experience is that vft_plug copied from version other than X10 is marked as BorisFX trial version.
It's possible. When installing X10 and (manually) BorisFX from the bonus, when installing Boris
Installation instructions must be followed and approved. Then copy and paste vft_plug.
RobertOZ
Post by RobertOZ »
There is no way I will install VSX10, knowing the issues I will have when uninstalling.
As I have a fully functioning BCC in VS2018, which I can use if the need arises, and I do have a fully functioning Graffitit7 in 2021 & 2022
Choi seong chul
ram: 64GB DDR4
When I copy from VS2018, Graffitit works fine though.
The BCC title appears as a trial version.
Now I can install VSX10 after upgrading windows 11 but
The program does not open.
But BorisFX can import and I'm in VS2021, 2022
All are being used.
kmoulds
ram: 32 GB
Post by kmoulds »
Thanks to everyone who posted a reply with help and suggestions.
You are all WINNERS in my book.
I got the BCC Title Studio up and running thanks to you people. But I still have a problem getting 'Lower Thirds' to work but this is the object of another post.
Cheers again from Kym
Cheers Kym
Choi seong chul wrote: Wed Mar 02, 2022 2:34 am Now I can install VSX10 after upgrading windows 11 but
I am having a similar issue running X10 on Windows 10
Very strange as it has worked in the past.
The program hangs with splash screen and a few errors relating to loading empty library?????
A work-round for me is to run FastFlick - create a small effect - Save and Share - choose Edit in Video Studio, program launches ok.
Go figure
