Cannot install VS 2022 Ultimate
bjtap1
motherboard: HP 843B U3E1
processor: Intel Core i7 8700 CPU
ram: 12 GB
Video Card: Intel UHD Graphics 630
Hard_Drive_Capacity: 1396 CB
Monitor/Display Make & Model: Samsung G246HL and Acer C32F39M
Corel programs: Videostudio 2023 Ultimate
Post by bjtap1 »
Does this attached jpg error message mean anything to any of you. After receiving this all further attempts at uninstalling and reinstalling Videostudio 2022 Ultimate have failed.
I have contacted support already. I can outline the many steps and attempts I have made and will do so upon request, but I am hoping someone might have some knowledge of what to do.
Thanks,
Barry
(BTW: I have been able to install Videostudio 2020 Ultimate with no problems during all this... the problem seems to be limited to the installation of Videostudio 2022 Ultimate).
glus
motherboard: MSI Z390
processor: Intel i9-9900K
Video Card: NVIDIA GeForce 2060
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Acer X233H
Corel programs: VideoStudio, Pinnacle Studio
Re: Cannot install VS 2022 Ultimate
Post by glus »
Hi Barry,
Can you please zip and share the log files from here:
C:\ProgramData\VideoStudio Log Files\VS2022
If you've tried multiple times, there may be many folders. Probably not necessary to zip them all, in case the file becomes too big to share here.
You can also send them to me as a private message.
Thanks, and I'm sorry about the trouble. Hopefully we can find a resolution soon. I have also shared this with a member of our support team, he may have seen something like it before (I haven't) and contact you about it.
Auz
Alludo
motherboard: Vanilla Build System
processor: Intel Core i7-4790 CPU
ram: 16TB
Video Card: NVIDIA GeForce GTX 750 Ti
Hard_Drive_Capacity: 16TB
Monitor/Display Make & Model: Samsung SyncMaster E2020
Corel programs: SME For WinDVD, VS, Painter
Post by Auz »
Hi Barry --
Easiest way to combat this would be to run the cleanup tool -- https://forum.corel.com/download/file.php?id=16228
I would suggest running it twice to verify all the entries on the right are removed. If you wind up seeing entries on the second run of the applet, please raise a support ticket with Technical support and ask to be transferred to Level 2 and get Austin's attention.
bjtap1
ram: 12 GB
Post by bjtap1 »
glus and auz,
Thanks for the replies. I just within the last half hour or so, have been able to MOSTLY remedy the situation. Before I attempted to install VS2022U I had installed and uninstalled the trial. On a whim, I decided to install the trial again and that worked. So this time I used the install icon to install with the license number and NOT uninstall the trial. During the install process it successfully updated from trial version to ultimate version. So some how uninstalling the trial version must of caused the problem.
Above I said MOSTLY remedied: When I attempted to update the free 'packs' in the welcome screen almost all of them had the same problem. They would not install because they themselves were 'open'. In some of the cases I shut down VS 2022U and was able to complete the install. Some of them did not install at all and some showed they were installed but are not working properly. Example of the latter is Adorage Volume 9. It appears but clicking on individual choices yields 'Error! Can't load image file on a red screen. Too many examples to list them all. Others appear to work but no effect actually appears.
I seem to recall some users in much earlier versions reporting a similar problem with Adorage Vol 9. So perhaps you could do a search for Adorage Volume 9 on the Board to see what comes up.
EDIT: I just did a quick search myself and came up with a complicated thread about Adorage problems, in which you were involved! See https://forum.corel.com/viewtopic.php?p=381828#p381828
phaseman
motherboard: ASUSTeK Computer INC. P8H61-M LE Rev x.0x
processor: 3.10 gigahertz Intel Core i5-2400
ram: 32gb
Video Card: ATI Radeon HD 7870
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Triple LG 24'
Post by phaseman »
unfortunately mine has same problem, only goes to splash screen. three install attempts used clean up tool, install used repair. Used Reveo uninstaller to remove all components. renamed file 25.0 but not luck.
MikeAlan
motherboard: Micro-Star International Co Ltd MS-7B86 4
processor: 3-60 gigahertz AMD Ryzen 5 3600 6-Core
ram: 32-768gb
Video Card: NVIDIA GeForce GTX 1050 Ti [Display adapter]
sound_card: onboard sound
Hard_Drive_Capacity: 5407-60 Gigabytes Usable Hard
Monitor/Display Make & Model: HPN HP M27fwa FHD [Monitor] (27.2"vis, s/n 3CM1
Corel programs: Corel VideoStudio Ultimate 2022, Corel -
Post by MikeAlan »
I too have the same problem. I have tried 3 times, each time rebooting the computer and using the VS2022_Cleanup.exe to clear the old install before retrying.
The install progress bar stops about 12mm before the end and in one case I left it there for 2 hours all to no avail.
All or most of the files appear to have installed.
MikeAlan
ram: 32-768gb
Post by MikeAlan »
Apologies, I should have included the Install Log File. Here it is.
Setup.exe.log
(111.6 KiB) Downloaded 101 times
josephlin
Alludo
motherboard: Intel Z490 chipset
processor: Intel Core i9-10900K
ram: 32GB
Video Card: nVidia RTX 2070S
sound_card: Realtek ALC892
Hard_Drive_Capacity: SSD 1TB
Post by josephlin »
Hi All,
The issue has been reported for a while and not sure if you are still experiencing the install issue in VS2022 or VS2023 now. Please advise it.
Cheers
Joseph Lin
Sr. Program Manager,
Corel PaintShop Pro / AfterShot Pro / VideoStudio
