Audio gets out of sync with video when I add text (title)
trenedurham
ram: 8 GB
Hard_Drive_Capacity: 237 GB
Monitor/Display Make & Model: Surface tablet
Corel programs: VideoStudio 2020, AfterShot Pro 3,
Post by trenedurham »
I'm a newbie but Ive done at least 6 videos using VideoStudio 2020. I record the video on my Samsung Galaxy Note 8 or my Surface 8 tablet running windows 10 pro. I record through the mic on the phone or the tablet. When I import the video, it plays all the way through, fine, no problem. But when I begin to add text in the Title area, after that point, the audio begins to go faster than the audio, progressively getting more and more out of sync. As mentioned, I've not had this problem before and I have not changed anything (that I know of).
I've read about the fps on the camera I use vs the settings in VideoStudio but I am mot fully clear on that. My surface tablet says it is recording 30 fps which is 29.97 (?) or something like that actually. When I look at the videostudio settings, I don't even see anything referring to fps.
I hope that is enough information. Thank you in advance for any help.
T
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Audio gets out of sync with video when I add text (title)
Post by asik1 »
For proper video information get Mediainfo
https://mediaarea.net/en/MediaInfo
Smartphone use variable fps so no good for editing. you need to convert it to a proper relevant fps.
Panasonic X900m, VXF1
trenedurham
ram: 8 GB
asik1 wrote: Fri Feb 11, 2022 4:34 pm For proper video information get Mediainfo
I used my tablet for this recording. It says 30 fps (29.97) Where in the corel software I change fps? Under settings -- Preferences -- Performance, I have autogenerate proxy selected and it says it is frame based. It is showing
MPEG-4 Files, 24 bits 1920x1080 30 fps
Frame based
