Opening PDF with no anti-alias asks for password
susb8383
Corel programs: Paint Shop Pro 24.1.0.27 x64
Post by susb8383 »
I'm brand new to PSP.
I'm trying to open a pdf of barcodes. However if I uncheck Enable Anti-Aliasing, it tells me "This file is password protected."
What would one have to do with the other?
I get this same error if I create the pdf myself (from MSWord, save as pdf).
Note that if I leave Enable Anti-Aliasing checked, it opens it fine.
Thanks.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: Opening PDF with no anti-alias asks for password
Post by Jean-Luc »
What is your PSP version? (your profile is not complete)
Jean-Luc
Post by Jean-Luc »
I tested with PSP 2022 and yes, that is odd. Password is required. It seems you have discovered a bug. It needs to be confirmed.
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
Confirming. . . I just tried with PSP2020, 2021 & 2022 and received the message password required. However, PSP X9 does not have this bug and opens the PDF with no issue when anti-alias is un-ticked.
splash3313
Hard_Drive_Capacity: 1tb
Post by splash3313 »
I don't have a problem opening PDF files in Paintshop Pro though it was a single image of a person. I just selected PDF as the format I wanted to open, found the file and pressed open.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Splash3313 your profile doesn't say which version of PSP you're using. But just to clarify, did it ask you for the size to open the PDF as? And if it did did you unselect "anti-aliasing"?
splash3313
I just opened the file in paintshop pro 2022 and it didn't ask for a password. However I did just go open and in file type pdf file so that it showed only pdf files and then opened the pdf i wanted. It could be how the pdf is created as it only had an image in it.
Jean-Luc
Post by Jean-Luc »
splash3313 wrote: Mon Feb 28, 2022 1:20 pm I just opened the file in paintshop pro 2022 and it didn't ask for a password.
It asks for a password if you uncheck antialias.
The problem has been reported to Corel. :)
susb8383
Post by susb8383 »
Thanks!
