(SOLVED) Round corners
jimbir
Post by jimbir »
How do I Round the corners of an image?
PSP 2018.
Epson V550 photo scanner.
Epson Stylus C88+ Ink jet printer.
Brother HL-3170CDW laser printer
Windows 10 64 bit.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Re: Round corners
Post by JoeB »
With the Selection tool, click on Selection Type on the Tool Options bar and select Rounded Rectangle. Draw out your rectangle and it will have rounded edges. Copy, Paste as New Image and the image will have rounded corners with transparency showing in the corners.
JoeB
Using PSP 2019 64bit
jimbir
Re: Round corners
Post by jimbir »
Thanks. Is there a way to change the size of the radius'?
PSP 2018.
Windows 10 64 bit.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Round corners
Post by LeviFiction »
If you need to change the radius, use the Vector Rectangle tool.
The general steps are
1) Draw out a rectangle of any size
2) On the menu run the following two commands to make the rectangle fit the image
Object -> Make Same Size -> Both
Object -> Align -> Center in Canvas
3) With the rectangle tool still selected, and your rectangle object selected in the layers palette, you can either drag out the corner or use the "Horizontal Radius" and "Vertical Radius" boxes on the tool options palette to adjust the radius of the corners.
From there you have several options.
1) Use the Shape Cutter (the options are on the Tool Options palette with any vector tool selected) this will auto-cut out a new image using the vector shape as a guide
or
2) Use the menu option Selections -> From Vector Object to create a selection of your image and copy and paste as new image
or
3) Use the selection from the rectangle to create a new mask layer.
jimbir
Re: Round corners
Post by jimbir »
LeviFiction wrote: Mon Jan 24, 2022 8:54 pm If you need to change the radius, use the Vector Rectangle tool.
Thank you for the instructions. There are a lot of things in this that I don't understand so please excuse me if I ask a lot of questions.
Lets start with general step #2
First question: Where do I find "the menu" and how open it? I'll do my best to run the commands.
PSP 2018.
Windows 10 64 bit.
ram: 6 GB
Re: Round corners
The main menu at the top of the program. You see a long the top "File" "Edit" "Image" "Effects" etc. You're looking for the menu named "Objects"
jimbir
Re: Round corners
Post by jimbir »
OK. I found 'objects'. I didn't know what to select so I clicked on 'edit'. The selections to the left of that were all grayed out. What's next?
PS How do I attach a screenshot?
PSP 2018.
Windows 10 64 bit.
Re: Round corners
jimbir wrote: Fri Jan 28, 2022 2:23 pm
not sure if things have changed over the years but this should help
https://forum.corel.com/viewtopic.php?f=63&t=57659
jimbir
Re: Round corners
Post by jimbir »
That link only shoes how to attach a file. You apparently can't paste an image from the clipboard
PSP 2018.
Windows 10 64 bit.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: Round corners
Post by Jean-Luc »
jimbir wrote: Fri Jan 28, 2022 5:01 pm That link only shoes how to attach a file. You apparently can't paste an image from the clipboard
This Webboard doesn't accept images from the clipboard.
Paste your image from the clipboard to PSP (Edit/Paste As New Image).
Save the image in JPG.
Attach the JPG file to your message. :)
ram: 6 GB
Re: Round corners
Here is a way too long video showing the method and different options available
https://drive.google.com/file/d/1A916X5 ... sp=sharing
It'll take a few minutes to fully finish rendering on Google's side but when it does it should be good quality video...the audio and presenter might be jacked up.
jimbir
Re: Round corners
Post by jimbir »
Thank you ! This told me everything I needed to know. Fortunately, I was able to slow the video down a little so I could follow it.
It sounded like he has videos on how to do other things. Do you have a link to his site or blog or even his name?
Jim
PSP 2018.
Windows 10 64 bit.
ram: 6 GB
Re: Round corners
I made that video. It's me. I have an old youtube channel under the same name. I also have a Wordpress blog but that's dedicated more to scripting than general use of PSP. Most helpful videos I've made, if any, are posted around these forums.
