PSP 2019 Layers
BenHer
motherboard: ASUS Z390
processor: I5 9600
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Corel programs: PaintShop Pro
PSP 2019 Layers
Post by BenHer »
Hi, I regularly restore old B/W photos and often have to deal with unevenly lit houses. The problem is most severe when I try to restore an aerial photo. The side that faces the sun is often over exposed while the other sides of the house are exposed OK.
Is there a tutorial dealing with layers that could solve my problem. I want to "mask out", a phrase from the analogue darkroom world, the correctly exposed parts and deal only with the other parts which may need different treatment.
Kathy_9
Hard_Drive_Capacity: 2TB
Re: PSP 2019 Layers
Post by Kathy_9 »
See if one of the tutorials on the Discovery Center helps you. It will get you familiar with using masks in PSP.
https://learn.corel.com/photo-tutorials ... ith-masks/
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: PSP 2019 Layers
Post by Jean-Luc »
You may create over- and under-exposed images of your original and use the three versions with the HDR Merge Exposure tool. Sometimes, it helps.
mdconner
HDR Merge Exposures is just greyed out
Post by mdconner »
In PaintShopPro Ultimate 2022 Manage Workspace. I have many shots with multiple exposures that I cannot merge. After selecting photos (although they do not have an orange border around them), I click FIle>HDR> Exposure Merge is greyed out and is unclickable. This function also does not work in the Essentials or Edit Workspaces either. What am I doing wrong? Please help as I am at a complete loss as to how to proceed.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: PSP 2019 Layers
Post by LeviFiction »
How are you "selecting" the photos? When I have a photo selected in either the "Manage" tab or the Organizer Palette in the "Edit" tab the only HDR option that's greyed out for me is Single RAW photo. If I have no photos selected in either mode all options are available. Also, are you in the "Complete", "Essentials", or "Photography" workspace?
Not that you have to use the HDR options. HDR, Photo Blend, and just manually aligning layers and using masking and blend modes are perfectly valid options. But it is weird you're having trouble with HDR merge.
mdconner
Re: PSP 2019 Layers
Post by mdconner »
Weird I must be. I select the photos in any of the modes with the same result. Nothing works. All options are greyed out. Maybe I should remove and reload?
mdconner
Re: PSP 2019 Layers
Post by mdconner »
After an uninstall a re-install and a reboot, every thing works
