I had PSP 2022 installed and working, changed some File Location settings, and now it won't start. I get the splash screen, then nothing. In Task Manager it doesn't show it.
PSP 2022 x86 does work.
I tried running Repair, I tried running the Update, even uninstalled and reinstalled and still it doesn't start.
When I did the uninstall, I did not [x] Remove User Files.
The reason is that I have loads of junctions to a set of folders that are common to multiple PSP versions. In other words, PSP X8, X9, 2018, 2019, 2021, and 2022 all are working from a single set of files. If I tell it to Remove User Files it will screw up all the other ones.
And again--it was working and not for just a little while, and x86 still works.
Does PSP have some kind of command-line parameters for "minimum start", "safe start", etc.?
PSP 2022 64-bit Won't Start
Rick_R
- motherboard: ASUSTeK Computer INC F2A85-V Pro
- processor: AMD A6-6400K APU
- Video Card: PowerColor AMD Radeon R7 240 2GB DDR3
- sound_card: On-board Realtek and AMD High Definition Audio
- Hard_Drive_Capacity: 16TB+375GB
- Monitor/Display Make & Model: SEIKI SE39UY04 39in 4K UHD TV
- Corel programs: PaintShop Pro 12-2022 Ultimate
splash3313
- Hard_Drive_Capacity: 1tb
Re: PSP 2022 64-bit Won't Start
You could try holding the shift key and then double click Paintshop pro version you want to use. This should reset any settings that you changed in that version, to default. If that does not start up then I would suggest going to Corel support as it could be a conflict somewhere in the settings or registry.
Before you reset, make sure you save any customized workspaces. Otherwise, they will be lost in the reset.
splash3313
The reason why I did not say save your settings is that could of caused your problems. Plus as they can't get into Paintshop pro they can't save any settings.
- sheng-si
- motherboard: Hp motherb
- processor: amd
- ram: 32 Gb
- Hard_Drive_Capacity: 1 tb
- Monitor/Display Make & Model: ASUS VG24VQR
- Corel programs: paintshop pro Videostudio 2022
I have same problem the 32bits version starts very slowly. Got first screen, looks nothing happened and then Yeh it opens.
The 64bits just the first screen and then it stops. Did try with holding shift key: no results.
Had to install 2022 again after very needed recovery of W11.
Never had problems before.
Installed 2021 too, so I can do something.
Installation was without any problem, both versions and both versions works well.
Admin FB Paintshop Pro NLD for dutch users.
splash3313
What Version of Windows 11 do you have, as that could of been the problem windows 11 update. In All honesty Windows 11 is still very buggy at present.
